How Do You Differentiate Between Polynomial and Rational Algebraic Functions?
Differentiating between polynomial and rational algebraic functions involves understanding their definitions. A polynomial is expressed as a sum of terms with non-negative integer powers of x, while a rational algebraic function is a fraction where both the numerator and denominator are polynomials. Examples provided illustrate that expressions like 3x^3 + 2x + 1 and 3x^2 + (x + 1)^(1/2) are polynomials, whereas 2x + 3/(x^2 + 1) and (x/(x + 1))^X are rational algebraic functions. The discussion emphasizes the importance of recognizing the structure of these functions to classify them correctly. Understanding these distinctions is crucial for algebraic analysis.
JasonRox
Homework Helper
How can you tell the two apart?
Here are some examples in the book:
1. 3x^3 + 2x + 1
2. 3x^2 + (x + 1)^1/2
3. \frac{2x + 3}{x^2 + 1}
4. (\frac{x}{x + 1})^X
Mathematics news on Phys.org
You just need to distribute.
#2 distributed is:
3x^2 + 1/2x + 1/2
and #4 distributed is:
\frac{x^2}{x+1}
After distributing all four are very obviously different
After relooking at your post I realized that you may not be comparing equations but instead classifying them.
A polynomial can be express as ax^n + bx^(n-1) + cx^(n-2) + dx^(n-3) … +c
I’d have to look up the definition for a “rational algebraic expression” but going from memory it is any expression that has only algebraic terms?
the polynomial 's power must be postive interger . that's the difference
A Polynomial (in x) is a linear combination of non-negative powers of x.
A rational algebraic function is just a fraction N(x)/D(x) where N and D are both polynomials.
In your examples 1. and 2. are polynomials while 3. and 4. are rational algebraic functions.
oh? i though the power of polynomial must be interger, i go check
No need to check you're correct. It was just a slip, I meant to say non-negative integer but only type non-negative. :o
Thanks, guys.
JonF said:
A polynomial can be express as ax^n + bx^(n-1) + cx^(n-2) + dx^(n-3) ? +c
JonF: use curly brackets to apply something (in this case ^) to an expression.
ax^n + bx^{n-1} + cx^{n-2} + dx^{n-3}...+c
Why would the constant term be equal to the coefficient in front of x^(n - 2)? ;)
argh, thank you
