Can Step up transformer amplify signals?
A step-up transformer can increase voltage but does not amplify power, as it is a passive device that cannot provide additional energy. Unlike transistors, which are active devices that use external power to amplify signals, transformers merely change voltage levels while maintaining the same power level. The discussion emphasizes that while transformers can enhance voltage, this is not considered true amplification in electrical engineering terms. The distinction between voltage magnification and power amplification is crucial for understanding their respective roles in circuits. Overall, transformers are useful for voltage transformation but do not function as amplifiers in the traditional sense.
bukks bunny
Hello friends.I was just wondering if a step up transformer can be used to amplify voltage signals like a transistor,as it step up input voltage at its output.?
Hi. Sorry, but you never get something for nothing.
A transformer is a Passive device. It cannot supply any extra power. It can change the voltage but the power it can provide will be no more than the original signal. A transistor, otoh, uses power from a supply (battery etc) to Amplify a signal; it is an Active device and can give you more signal power. That's the difference.
If you have a problem with all that then you need to find out about Volts, Current, Resistance and Power and what the terms actually mean. The basics are fairly approachable.
If you have a signal from a source that will supply a lot of current at a low voltage, then a transformer may be able to change that signal so its voltage swing is greater but it will only supply correspondingly less current into a load.
A normal transformer can't provide power gain but it's possible to control the "energy coupling" from input to output with a low power signal using a 'Mag-Amp".
http://en.wikipedia.org/wiki/Magnetic_amplifier
You should make it clear that the signal in this case, also, uses / controls an external source of power,
Sure, the energy of the control signal is not being boosted but a small change in signal input power can cause a large change in external power only using the magnetic fields of transformers so it meets the classic definition of a amplifier.
I know you know - it was for the OP's benefit.
hi guys: So is it a signal or out put power that's in question? A signal being used as a control?
Not sure what you mean but we were just making sure the OP understood my response to the question. A simple input/output transformer is not an amplifier but it is possible to design a transformer circuit that can operated as a amplifier.
In a MAG-AMP the signal is a input control that's external to the output but so is the signal in a electron tube or a FET (usually).
Nope, and yes may be. it depends upon your source. if it is capable to supply larger currents then yes. If you want to increase voltage and amount of current does not matter for you then obviously transformer can amplify the voltage(but current will be reduced to make the power constant p=vi).
Imp Note: It also depends on your signal. If frequency is too high then input inductance will eat out your signal resulting in attenuated signal at out put. Also high frequency signals require special core transformers having ceramic cores. Ordinary transformers don't work there.
I think most of use would use the word "amplify" to mean (possible) power gain in a circuit. The input/output function of a "Step up" transformer (a component in a circuit) is not an amplifier because it's a unity or less power transformation that only changes the ratio of voltage and current.
My mag-amp example may have muddied the waters a bit but it's a good example of how a component when operated in a non-linear (core saturation) manner can provide power gain in a circuit without what we would normally think as 'active' components.
It's ok if we define an active component as one that requires an external power source for it to work. Magnetic, thermionic or semiconductor would all qualify.
A 'transformer' merely 'transforms' impedance and supplies no extra power.
OP specifically asked about amplifying voltage and it most of the responses discuss amplification in terms of power.
The quick answer is yes, a step-up transformer can amplify voltage. Let me give you an example. I was working for a company that used ferrite antennas resonant to 200 kHz. The coil around ferrite rod had a low impedance tap to connect to the coax cable. In order to improve the range I discovered by supplying DC through the cable, I could operate a single stage FET amplifier with the gate connected across the full coil instead of just the low impedance tap. Sure the FET added gain but not as much as the difference between using the voltage across the full length of the coil and the tap.
This can be dismissed as a matter of semantics but I feel it's more important than that.
The word 'amplification' is used, loosely (sloppily, even) in both cases but it strictly means 'making a signal bigger' i.e. more powerful. When specifying the performance of an 'amplifier'. Often, you'll find the expression Voltage Gain is used. It's a very useful piece of information but, without other information says absolutely nothing about the Power Gain, which is always what is really important. Unless input and output impedances are specified you have no idea how much use the amplifier will be (or the signal emerging)..
If I go into a shop and buy a 10dB Amplifier then I assume it will make an input signal ten times more Powerful - which is what counts.
You can only talk in dB, in a valid way, when you mean a gain in power. As it happens, when you are operating with the same impedances, the voltage gain can be calculated from the specified gain in dB - but this is secondary and is often grossly misused. People will talk of "Voltage dBs" without thinking what they mean and can easily fall down a hole at a later stage. Bringing dBs into the argument may be making things harder for some people but it is something that really needs to be treated rigorously.
Your specific examples of using a FET is just demonstrating that appropriate matching improves performance. Your FET is providing Power Gain - which is what the early stages of a receiver need - and making the best use of what you have been getting at the input. A transformer (whether or not you could actually build it is another matter) could have done a transformation of impedances - but it wouldn't necessarily have improved the noise situation, for instance.
The dear old emitter follower is definitely an Amplifier (with a capital A) yet its voltage gain is always a tad less than unity.
I think you are defining the word to fit your argument. Since the OP only indicted a concern with voltage and since the following definition does not specifically refer to power, I take it to mean making larger, greater or stronger the voltage. Speaking of semantics...
http://dictionary.reference.com/browse/amplify?s=t
am·pli·fy
[am-pluh-fahy] Show IPA verb, am·pli·fied, am·pli·fy·ing.
verb (used with object)
1.
to make larger, greater, or stronger; enlarge; extend.
2.
to expand in stating or describing, as by details or illustrations; clarify by expanding.
3.
Electricity . to increase the amplitude of; cause amplification in.
4.
Archaic. to exaggerate.
verb (used without object)
5.
to discourse at length; expatiate or expand one's remarks, speech, etc. (usually followed by on ): The preacher amplified on the theme of brotherly love.
We are not talking about power gain in this post, we are talking about voltage gain. Is not voltage gain defined as Vout/Vin?
There are applications where the voltage gain is important but power gain is not. Ironically given your statement, "Your FET is providing Power Gain - which is what the early stages of a receiver need" the receiver front end is one in which voltage gain is more important than power gain. This is because when stages are impedance matched, you lose 30% of the voltage between stages. If each succeeding stage in a receiver has a higher input impedance than the output impedance of the stage ahead of it, you lose less voltage between stages resulting in higher overall voltage gain.
This argument could run and run but we all know that a transformer is not an amplifier, in any language. Voltage multiplication merely changes impedance. Equating a transformer to an amplifier is like equating a mechanical lever to a servo - it's only half the story.
Dictionary definitions of words that are used colloquially are not relevant to a specialist subject.
In the early stages of a receiver (designed to receive low level signals), the signal power needs to be brought above the local noise power as early as possible. Most receivers use some transformation to present the input signal at an appropriate impedance to suit the first stage amplifier (I think they refer to this as noise matching?). Merely transforming to a higher voltage is of no help to SNR whatsoever because that represents a higher noise resistance. The noise Power just depends upon the temperature of the equivalent input resistance and a good receiver attempts of limit significant noise contribution to the first stage only, when possible. It can only do this by true (power) Amplification and, of course, noise matching is used.
I agree that voltage gain is often the only thing that counts in specific applications but that is only in mid-level circuits. It is not relevant in input stages where low signal levels appear or in output stages where you really need some Power. My pernicketiness was just there in order to get the word 'amplification' into proper perspective. Transformers do not 'amplify', in any strict sense of the term; they may 'multiply voltages' but that's a different matter.
Hi bukks, http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
A transformer can step up the voltage, but in EE this is not referred to as amplification. It is termed magnification. The word "amplification" is restricted to applications involving an active device, viz., an amplifier. The distinction may seem slight, but in practice it really isn't.
Spot on.
Please support your statement with a reference.
Et tu.
I'd like to see a reference that uses the word "amplify" to describe what a transformer does. It is much easier to prove a positive than a negative. Ie, the word "amplify" (or any relative) is not used in the wiki to describe the purpose of a transformer. That's not definitive proof, but it does imply it isn't an appropriate word use.
On the other hand, the wiki for "amplifier" says:
An electronic amplifier or amplifier is an electronic device used for increasing the power of a signal.
Which implies that the use "voltage amplifier" is an improper usage of the term.
In formal network theory it would be called "voltage transfer ratio".
Colloquially, I've always used "voltage gain" to mean an increase in voltage from input to output without implying anything about power gain or loss.
Anyone can look in wiki and see what they have to say about what an amplifier does. The phraseology they use is "modulating the output of a power source". A transformer doesn't do that.
I know wiki may not be the ultimate source and we are only arguing semantics but you really are not helping peoples' general understanding by insisting otherwise.
Would you not agree that there is at least a difference between devices with and without a power source? In which case, what term would you use to differentiate?
Again, back to the OP's question, interpreted as the OP intended. I have already shown in post #13, that the OP used the word "amplify" within the context it is normally used, i.e. "to make larger, greater, or stronger; enlarge; extend." We do not expect all posters to be familiar with technical terms and use them in the narrow sense that may be common among engineers.
However, even technical dictionaries are divided on this issue. Here are a few references.http://www.csgnetwork.com/glossarya.html
amplifier
A circuit that increases the voltage, current, or power of a signal.
http://elearning.zaou.ac.zm:8060/Sc...nary of Electronics - Stan Gibilisco 2001.pdf
amplifier
Any device that increases the magnitude of an applied signal. It receives an input signal and delivers a larger output signal that, in addition to its increased amplitude, is a replica of the input signal. Also see CURRENT AMPLIFIER, POWER AMPLIFIER, and VOLTAGE AMPLIFIER.
voltage amplification
1. Abbreviation, Av. Amplification of an input-signal voltage to provide a
higher output-signal voltage. 2. Abbreviation, Av. The signal increase (Vout/Vin) resulting from this process. Also called voltage gain.
voltage-amplification device A low-current device designed especially for voltage amplification. It provides little or no power amplification.
voltage amplifier An amplifier operated primarily to increase a signal voltage. Compare CURRENT AMPLIFIER and POWER AMPLIFIER.All these definitions are broad enough to include transformers as voltage amplifiers. As in the second definition for voltage amplification, (Vout/Vin) is voltage amplification, also called voltage gain. In the context of the question, that of whether transformers can amplify voltage similar to a transistor, the answer has to be yes.
Perhaps you could give an example where any of those 'types' of amplifier have been used and called an amplifier and consist only of a transformer.
Or could you also quote an example in which a voltage amplifier actually has a lower input impedance than its output impedance - resulting in no power gain? (or the inverse, with a current amplifier) Using an active amplifying device in a way that actually produces no power gain (strictly) would usually be poor engineering - except, perhaps, when a 'buffering' function is required and a transformer provides none of that.
Is not the whole point, for most posters of questions on this forum, to get themselves better informed about the topic on a technical level? They might as well be having a conversation down the pub with their friendly Bricklayer or Professor of History if they don't want to learn something from a reasonable authority about the subject of their question. Common usage of words is not applicable to any specialist topic in Science. It would too often be mis-usage - as in this case.
As for the actual wording of the OP. As has been stated before, the appropriate word would have been 'magnify' and not 'ampify' and I don't think pointing that out has causes any offense. bukks bunny doesn't seem to be complaining of rough treatment.
As its name suggests, a Transformer, Transforms.
Now that's a new perspective. (Even though you don't follow through with it.)
Maybe the OP wasn't questioning the industry usage of the word "amplify", maybe bukks bunny was questioning the use of transformers, and wondering whether they have applications apart from in AC power, i.e., I was just wondering if a step up transformer can be used to step up voltage signals in audio or RF applications?
Well, if that's the question, then yes, transformers are extensively used for audio and radio frequency applications, and they can be used to step up or step down. Ordinary mains transformers don't work well for higher frequencies, there need to be some manufacturing and material changes for these higher frequencies, but the transformers still work on the same principle.
Alas, I think bukks bunny has been scared off by the forum ruckus and retreated into his burrow. :shy:
I notice the OP uses the phrase "like a transistor". A transformer doesn't have or need a source of power so, in that respect, it is very much not like a transistor.
Perhaps bukks bunny could stick his nose out of his burrow, briefly, to say what he's got from this barrage of ire he's unleashed :smile: and tell us what he meant by his question. One could hardly blame him if he never came back - that would be a shame.
heloo friends.First of all,sorry for my long leave as i had fallen sick.And thanks for all your response.What i was trying to figure out was that if a transformer can increase the amplitude of a voltage signal while preserving its exact shape why not it be used in place of bjt or fet votage amplifiers (as both do the same job).?
When all you need is increased amplitude of a voltage signal and when the pass-band is narrow then a transformer can be used. You need to realize that a transformer provides no buffering, though, and that precludes many of the functions that electronics performs.
A transformer is used when you want to transform the impedance of a signal, i.e. when it's appropriate.
If you have no power supply available, there are times when a transformer will perform a useful function. Why do you want it to be more than that?
Welcome back. There should be a warning given to newcomers that involvement with PF can be a health hazard.
After the signal has been stepped-up by the transformer, what are you going to do with that signal? Most times you're going to feed it into an amplifier or some other electronic circuit. So why not incorporate the "magnifying" function into your electronic circuit and skip the transformer⁈ :smile:
They don't.
  • #31
As the prime concern was increasing the voltage amplitude(voltage gain) i guess i could use a step up tranformer in circuits where size doesnot matter.
  • #32
Do you 'have a thing' about transformers?
It is possible to knock a nail in a piece of wood, using a pickaxe but why would you want to?
Whilst there are occasions when all sorts of alternatives can be used to achieve a result, why not think in terms of using the standard approach? As I said before, there may be good reasons why you should not use a transformer in some circumstances. Wide-band transformers are very problematic and, of course, have infinite insertion loss at DC. They have their place but they are not amplifiers - end of.
This thread is going nowhere now. You have your answers so make your choice.
