Can the integration of sine be proven using Euler's formula?
  • Context: Undergrad
  • Thread starter Thread starter mnada
    Integration
The discussion revolves around the integration of the sine function, exploring various methods of proof beyond the fundamental theorem of calculus. Participants consider approaches such as power series, Riemann sums, and Euler's formula, while also discussing the implications of constants of integration.
  • Some participants inquire about proofs for the integral of sin(x) beyond the fundamental theorem of calculus.
  • One participant suggests using power series for sin and cos as a method to derive the integral.
  • Another participant proposes using Riemann sums to prove the integral, expressing uncertainty about the approach.
  • There is a discussion about the importance of the constant of integration when integrating sin(x), with one participant noting that it is arbitrary.
  • One participant mentions that the derivative of -cos(x) yields sin(x), suggesting this as a simpler proof method.
  • Another participant expresses confusion about a plot related to the integration of sin(x), questioning its accuracy in representing the integral.
  • A later reply indicates that the integration of sin(x) can be viewed geometrically as the area under the curve, linking it to the concept of integration.
Participants express various methods and ideas for proving the integration of sin(x), but there is no consensus on a single approach. Some methods are proposed while others are questioned, indicating ongoing debate and exploration.
Participants reference different mathematical concepts such as Taylor series, Riemann sums, and Euler's formula, but the discussion remains open-ended with unresolved questions about the best approach to prove the integration of sin(x).
mnada
Is there any proof for the integration of sine function beside the "fundamental theorem of calculus"
I know that the derivative of sine function is driven by the limit of sin(x)/x , is there a way to prove the integration of sine like this.
Thanks
Er, what exactly are you looking for here? Are you looking for a proof that the integral of sin(x) is -cos(x)?
Yes, exactly, this is what I am looking for
The power series for sin and cos are one way to look at it. You can also derive it from the definition of derivative and the angle addition formulas.
I'm wondering if there would be some way to prove it using Riemann sums, which I think is what the OP is going for. But I'm not sure how to do that... set \Delta x to 1/n, I guess, and then what for sin(xi)?
I guess you could do something like that, but the differentiation/integration are readily available (and easy to derive) for your standard a . x^n, which is a lot easier to do on a term by term basis.
I remember a very very long time ago (when I was in high school), we used some results of certain limits (like lim sin(x)/x as x -> 0) and the definition of a derivative to get sin(x) from first principles. That may be what you're asking but to verify its along these lines:
http://www.math.com/tables/derivatives/more/trig.htm
Actually this is exactly what I hope to find. a way to prove it using Riemann sums.
I didn't ask this question before until I noticed that the integration of sine looks this
How can i tell from the figure that the integration is -cos(x)
It would probably be easier to show that the derivative of -cos(x) is sin(x), using the difference quotient definition. After that you could use the fundamental theorem of calculus (assuming you can use that?)
chiro said:
In case you're unaware of what power series are (and taylor series) see:
http://en.wikipedia.org/wiki/Taylor_series
I got your point but if I integrate sin(x) as in the form of Taylor series :
I end up missing 1
it should be -cos(x)+1
You're forgetting about the constant of integration. This is exactly the reason that it's important, the integral is not complete without it!
In this case can you help me to show how to calculate C. it should be -1 in order to have the integration of sin(x) as -cos(x)
I'm not sure what that plot is showing, but it's not the integration of sin(x) to get cos(x). At first glance the curve doesn't have the correct period or height to be the integral of the sine curve, but even if the two curves were plotted on different scales, the large yellow curve is not just a cosine. It looks more like a sin^2(x) curve - look at the way the curve bends as it reaches the x axis, and compare it to the sine curve beneath it. EDIT: Okay, it's a cos(x)+const, I guess I missed that.
Yes its an arbitrary constant. If you want it to be -1 then you make it -1. That's what arbitrary means.
Why is it arbitrary? Because the derivative of any constant is zero. It doesn't have to be any specific number in order to have this property.
Thank you all for your help. I really appreciate it.
First of all I understood the idea of C and how to get the integration of sin by Taylor series.
I also found another mathematical proof which is a kind that I was looking for "by using Euler’s formula
http://www.mathslogic.com/integration-of-trigonometric-function-sine/
For me now the mathematical proof is set.
For the above graph the thick curve is the integration of the sin as the area under the curve (note that the integration of sin from 0-pi is 2 and this is what you have here).
you can look at this graph as 1-cos(x). My last goal is how to bring together the mathematical solution with the geometrical solution
Thanks
  • · Replies 139 ·
11K
12K
