Can Two Particles Achieve Perpetual Motion Through Attraction and Repulsion?
The discussion centers on the theoretical concept of two particles, one with positive mass and the other with negative mass, interacting through attraction and repulsion. It concludes that such a system cannot achieve perpetual motion due to the violation of Newton's third law of motion, as one particle attracts while the other repels. The idea of these particles accelerating without an increase in momentum or kinetic energy is explored, suggesting that if negative mass existed, it would be ejected from regions of positive matter. Ultimately, the impossibility of this scenario is established, reinforcing the principles of physics that govern motion and energy.
  • Understanding of Newton's laws of motion
  • Familiarity with concepts of mass, including positive and negative mass
  • Basic knowledge of particle physics
  • Comprehension of kinetic energy and momentum principles
  • Research the implications of negative mass in theoretical physics
  • Explore the principles of perpetual motion and thermodynamics
  • Study the behavior of particles in spacetime
  • Investigate the concept of forces in particle interactions
Physicists, students of theoretical physics, and anyone interested in the fundamental principles of motion and energy in particle systems.
T@P
I had an idea which i can't fully realize because i don't know the physics behind it. Here it is: imagine two particles, for example a and b. imagine also that a is attracted to b but b repels a. In this case, both atoms would essentially travel in a straight line forever assuming they repel and attract each other with the same force. what is wrong here? i know this cannot exist because it is a perpetual motion contradiction (there is no perpetual motion). But at the same time, they could go at a constant velocity, that is no acceleration. Can someone explain this to me in greater detail?
Why not just take two particles that are neutral and set them off into space with the same velocity? It would be the same thing.
If it could exist, then a negative mass would act as you describe. With mass negative, then acceleration would be in the opposite direction from an applied force.
Example: Take two particles at rest, one with a unit of positive mass and the other with a unit of negative mass. Place a positve charge on one particle and a negative charge on the other, and release. The force on each particle is directed toward the other particle. The positive mass particle accelerates toward the negative mass particle. The negative mass particle acclerates away from the positive mass particle and an accelerating chase begins.
Note that because the net mass of the two particle system is zero, the two particles together can accelerate without an increase in momentum or kinetic energy, so the system speed would eventually approach c. Speculating wildly, this could be the basis for explaining why no one has ever seen any negative mass, because it would be rapidly ejected from regions with a preponderance of positive matter.
but it wouldn't violate thermodynamics cause there doesn't need to be friction
  • · Replies 32 ·
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 30 ·
