Can You make an object move faster than the speed it was hit?
  • Context: High School
  • Thread starter Thread starter Botanix
    Speed
The discussion revolves around whether an object can be made to move faster than the speed at which it was struck, particularly in the context of collisions involving varying masses, such as a fist hitting a stationary object. Participants explore theoretical implications, practical examples, and the nuances of collision dynamics.
  • Some participants suggest that it is not possible for an object to move faster than the speed of the striking object due to the conservation of momentum and Newton's third law.
  • Others argue that under certain conditions, such as in elastic collisions, it may be possible for the struck object to exceed the speed of the striking object, particularly when considering mass differences.
  • A participant proposes a specific example involving a heavy object hitting a lighter one, questioning the resulting speeds post-collision.
  • Some participants emphasize the complexity of real-world collisions, noting factors like friction, resilience, and the forces acting on the bodies involved.
  • Discussions include the need for clarity in defining the conditions of the collision and the reference frames used for analysis.
Participants express differing views on the possibility of exceeding the striking speed, with no consensus reached. Some maintain that it is impossible, while others assert that it can occur under specific conditions.
Limitations include the assumptions about the nature of the collision (elastic vs. inelastic), the masses of the objects involved, and the effects of external forces like friction and air resistance. The discussion also highlights the importance of defining the reference frame when analyzing speeds post-collision.
Botanix
Hi
Simple question
For example if I punch something, or swing at it, Can i make it move faster then the speed of my swing/punch?
What do you think?
When you throw a ball at a wall, will it move faster than the wall after impact?
Ok so as a quick answer, no? That would deny 3rd Newton Law?
Have you tried throwing a bouncing ball at a wall?
OK I give another example
I hit an object and my arm weight 5kg, then I hit an object and my arm weights 30kg, will that object move faster then the speed of my arm in 2nd case?
This is not really my question ( because I know the answer is no, obviously ), I just want to show it to sombody who thinks it is possibile ^^. And I believe an answer from Physics forum should be sufficient...
So please answer, yes or no?
You are wrong and stuck in that mindset. The answer is yes. It is perfectly possible (and even necessary) that the thing you hit gets a larger velocity, or it would go right through your hitting device.
I suggest starting with a basic example where a heavy object of mass M and velocity v hits a smaller object of mass m at rest in an elastic collision. What velocity will the smaller object have after collision?
You did not understand my question, my english is not good...
If I hit a person, with 5kg arm will he fly with the speed exceeding speed of my arm?
If I hit a person, with 30kg ( same speed as in 1st example ) arm will he fly with the speed exceeding speed of my arm?
I am talking about hittin an object that is not moving like in example, hitting somebody.
Obviously in 2nd case he will fly with speed grater then in 1st case, but in both cases that person will not fly with speed higher then speed of my arm?
You need to get rid of the example of hitting someone, a punch is far from being an idealised collision between an arm and whatever is being hit. Even in the case of an idealised collision, it depends on the initial conditions and what you assume about the collision details and what you actually mean by your question, i.e., moving faster than the arm when? The arm is also going to change velocity. The arm is also attached to a body, which is standing on ground and there will in general be non-negligible forces here - this is why your situation is not an ideal collision.
I also suggest you try to figure out the example I gave.
I am not sure what is wrong with my example, its fairly simple for me.
There is a simple quetion really. Object A ( moving fist ) hits object B ( not moving ), will object B have higher speed then the speed of object A before it hit object B?
Why don't you actually work out the example from post #8? It is fairly simple and only involves conservation of momentum and energy. It will give you more insight to what is happening.
Because he will not understand an example from 8th post. What is Your answer for my specific question in post 12?
"There is a simple quetion really. Object A ( moving fist ) hits object B ( not moving ), will object B have higher speed then the speed of object A before it hit object B?"
Keep in mind, object B weight more then object A
This you have not specified earlier in the thread and it is a crucial piece of information.
Still, it is not clear that a punch can be modeled in this fashion due to forces acting throughout the body and contact forces may be present to the ground.
Let me also add that we are not an average just-give-me-an-answer forum. Our policy is to keep such answers to a minimum and instead help posters arrive at the correct conclusion themselves.
"This you have not specified earlier in the thread and it is a crucial piece of information."
Yes I am sorry I thought I did specifie, that objec A ( fist ) and object B human, and human body does weight more then fist.
"Still, it is not clear that a punch can be modeled in this fashion due to forces acting throughout the body and contact forces may be present to the ground."
Yes I understand this is not such simple example because of many variables like resilience.
But in the conditions I specified ( fist is not very resilent, neither is a face ), can my fist make make him fly ( let's assume that I am able to make him fly in the first place ) with speed exceeding ( and this is what i focus on, exceeding ) speed of my fist? For me this is not possibile because
1. Person I hit weight more then my arm.
2. Neither my fist or his face are resilent ( so ball example does not apply here )
3. There is friction, he is standing on the ground.
4. Ther is air ( resistance ).
So in this specific conditons, is it possibile that my fist will make him fly with speed greater ( crucial ) then the speed my my fist had before I hit him? The way I see it, it is not possibile.
I am trying to find that on my own but however I look at it I don not see a way for it to be possibile and I just need a confirmation ( this is really a real life example, only fact that is not real is me sending him flying but let's assume i can do that )
That's possible.
Then no.
It is just hard for me to make it clear what I ask for, I started learing english a year ago but looking at post 16 i think it is now clear what I am asking for.
Indeed it is, and your answer is in post #17... which landed so close to this one that you may not have seen it before you clicked "POST REPLY" for this one.
The maximum speed after the collision is the difference of the speeds of A and B.
Proof: in the rest frame of A (at the moment of the collision or, alternatively, assume A is not accelerated) B with collide with A at rest.
If A is much more massive than B and if the generated heat is negligible, then B's speed will be reversed.
Thus after the collision, in th elab frame (that is where you are at rest) the speed of B will at most be the sum of the speed of A and the reversed speed of B, that is their difference.
Btw I also neglected relativity, qed etc.
Tennis anyone? The ball will go a lot faster than the racquet.
Indeed, which is why I have already made several comments regarding the non-applicability of considering the hit as a simple two-body collision with only the arm/fist and whatever is being punched. OP's later comments restricts the collision to an object hitting something with larger mass.
This is simply untrue and depends on the reference frame. If you take an elastic collision of a light stationary object with a much heavier object, its speed after collision will be twice the relative speed. (Note! You likely did not mean the difference of speeds, rather the magnitude of the difference of velocities.) The maximum relative velocity after collision is bounded from above by this number.
Correct I was publishing faster than I thought.
Just for info.. It seems to be generally accepted that a golf ball will go about 1.5 times the speed of the club..
http://golftips.golfsmith.com/swing-speed-vs-ball-speed-1637.html
What's curious is this comment..
According to noted golf trainer Robert Cotter, the best way to increase ball speed does not necessitate increasing the speed of the swing. Instead, the focus should be on increasing the speed of the ball while keeping the swing speed constant.
I wonder how he managed that without changing ball or club?
The name of it escapes me right now, but there is a "cannon" that works exactly on this principle. It's essentially a series of progressively larger balls (from top to bottom) stacked on top of each other. You let the whole thing fall, and when the bottom ball hits the ground, the top small one shoots up like a bullet. Very cool device.
I believe the answer you are looking for is no. If object A collides with object B, it is only capable of accelerating object B to the same velocity as its own. Once it reaches that velocity, there is no further acceleration. For example, if a locomotive encounters a toy wagon, the toy wagon will be accelerated until it reaches the speed of the locomotive, but then there is no more acceleration so it does not go any faster than the locomotive.
As has already been discussed and answered in this thread, the above statements are simply not correct.
As the OP has already been answered, this thread is closed.
  • · Replies 27 ·
  • · Replies 16 ·
  • · Replies 55 ·
