The short answer is yes, but it's a tradeoff, and you don't get multiple results at the same time, but instead a single superposition.
The more information you obtain, the more the superposition is broken.
The measurement process itself is an interaction between the measured object and the measurement device, where the quantum state of the measurement device becomes correlated (or entangled) to the quantum state of the measured object.
If you make this interaction weak, the correlation is weak, and you only get a little bit of info, but the state of the object is only weakly disturbed.
If the measurement interaction is strong enough that knowing the state of the measurement device tells you as much as possible about the measured object, the disturbance to the state of the object is maximum as well.
Unfortunately, I can't comment on whether or how weak interactions would be applicable in the field of quantum computing.
You'll be interested to know what you describe falls under the field of quantum weak measurements.
https://arxiv.org/abs/1305.7154
There's some really neat things you can do in this field, such as ultra-sensitive measurements of beam-deflections less than a pico-radian in angle:
http://www.pas.rochester.edu/~jhgroup/papers/dixon-prl-09-04.pdf
For reference, a pico radian is approximately the angle subtended by a hair's width (~15 microns) over the distance from the Earth to the Moon.
The advantages also extend to ultra-sensitive displacement measurements in general (e.g. frequency shift):
http://www.pas.rochester.edu/~jhgroup/papers/starling-pra-10-12.pdf
Besides precision measurement, weak measurement techniques provide a much simpler way to directly measure the quantum wavefunction:
https://arxiv.org/abs/1112.3575
More recently, it's been shown that the interaction doesn't have to be weak to still work for this kind of quantum state measurement:
https://arxiv.org/abs/1504.06551
