MHB Can you solve this problem using bar models and ratios?
  • Thread starter Thread starter SDAlgebra
    Models Ratios
The discussion focuses on solving a problem involving ratios and bar models related to counters in three boxes. It outlines the relationships between the quantities of counters in boxes A, B, and C using equations derived from given ratios. The ratios are specified as 5:3 for boxes A and B, and 2:1 for boxes B and C. Additionally, it describes the changes in the number of counters after some are removed and moved between the boxes, leading to an equal count in each box. The thread emphasizes the importance of showing effort in problem-solving by writing relevant equations.
SDAlgebra
I need help with how to use bar models with these kinda stuff. Thanks
Mathematics news on Phys.org
This is not pre-uni topics, but i'd just like to know the answer thanks! 😊
This is, in fact, a middle or high school-level problem. https://mathhelpboards.com/help/forum_rules/ ask thread starters to show some effort. In this case this may mean writing equations describing the relationship between the quantities of counters in the three boxes or describing what you do and don't understand about this problem.
Let a be the number of counters in box A, b the number of counters in box B, and c the number of counters in box C.
"The ratio of counters in box A to box B is 5:3."
so a/5= b/3 and 3a= 5b
"The ratio of counters in box B to box C is 2:1."
so b/2= c/1 and b= 2c.
"Some counters are removed from box A."
Call the number of counters removed x. Now there are a- x counters in box A.
"54 counters are moved from box B to box C."
Now there are b- 54 counters in box B and c+ 54 counters in box C.
"There are now the same number of counters in each box."
a- x= b- 54 and b- 54= c+ 54.
We have four equations
3a= 5b
b= 2c
a- x= b- 54 and
b- 54= c+ 54
to solve for a, b, c, and x.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
