Cancellation of the electric field from opposite charges
5 replies · 9K views
Shohel chowdhury
Electric field of opposite charges, cancel out each other, is it right?
Don't know which level is really this question.
If you mean the electric field outside(*) the charges is approximately zero at large enough distance from them, it's ok.
(*) The electric field between the charges is not zero, not even approximately.
lightarrow
If you mean like with a non-ionized atom, then yes, the external E-field a ways away from the atom is zero, since the net charge of the electrons and protons cancels out.
But if you mean when the two charges are separated by some distance on the order of your measuring distance, then the E-fields are summed vectorially (magnitude and direction). The E-field exactly in the middle between two like charges is zero, but you can see that the E-field in general from two charged particles is pretty complicated around them...
https://i.stack.imgur.com/pNHut.jpg
Very nice picture. But the OP referred to opposite charges.
lightarrow
lightarrow
Oops, thanks! :smile:
