Cannot figure out how to solve this differential equation
cross652
dy/dx= 1/(x^2-xy)
I have tried all the basic steps in an attempt to make it take the form of:
separable
exact
homogenous
bernoulli
linear
I have tried substitution with:
y=ux
u=x-y
u=x^2-y
I cannot for the life of me figure this out, thank you for any help.
Well, you might try do invert it, and solve instead:
\frac{dx}{dy}=x^{2}-xy
Isn't that sort of Bernoulli-like? Don't remember all those tricks any longer..
EDIT:
If I have done this correctly, we should get something like:
x(y)=\frac{e^{-\frac{y^{2}{2}}}{\int{e}^{-\frac{u^{2}}{2}}du
Arildno, there seems to be something wrong with the formula, the latex image failed to generate. I think you forgot a \frac.
Anyway, this is the right approach to solving the equation, don't forget the integration constant :-)
[Edit]
Some more explanation and intermediate steps might be useful. The equation will become after setting z=x and t=y (in order to avoid mistakes)
\frac{dz}{dt}+tz-z^2=0
This is a Riccati type equation, which is in it's general form:
\frac{dz}{dt}+Q(t)z+R(t)z^2=P(t)
and can be transformed into a second order linear differential equation by using the substitution:
z(t)=\frac{1}{R(t)u}\frac{du(t)}{dt}
In our case this is:
z(t)=\frac{-1}{u}\frac{du(t)}{dt}
Differentiating this gives (leaving out the independent variable notation):
\frac{dz}{dt}=\frac{1}{u^2}\left(\frac{du}{dt}\right)^2 -\frac{1}{u}\frac{d^2u}{dt^2}
Substituting this in the orginal equation gives:
\frac{d^2u}{dt^2}=-t\frac{du}{dt}
Which has the following solution:
\frac{du}{dt}=A\cdot e^{-\frac{t^2}{2}}
And thus:
u=A\int e^{-\frac{t^2}{2}}dt+B
Using the transformation:
z(t)=-\frac{1}{u}\frac{du}{dt}=-\frac{A\cdot e^{-\frac{t^2}{2}}} {A\int e^{-\frac{t^2}{2}}dt+B}
Which is after dividing with A and setting B/A=C:
z(t)=-\frac{e^{-\frac{t^2}{2}}} {\int e^{-\frac{t^2}{2}}dt+C}
[Edit 2]
It is indeed the solution, substituting back in the original equation shows this.
There might be easier ways to solve this, but I can't think of any.
Another way to deal with equation is the following.
Change the independent variable x=e^t, thus y'=e^{-t}\,\frac{d\,y}{d\,t} in order to have for the inital ODE
\frac{d\,y}{d\,t}=\frac{1}{e^t-y}\Rightarrow \frac{d\,t}{d\,y}=e^t-y
Now define t(y)=u(y)-\frac{1}{2}\,y^2 in order to get rid of y and make the ODE separable, i.e.
\frac{d\,u}{d\,y}=e^{u-\frac{1}{2}\,y^2}\Rightarrow e^{-u}\,d\,u=e^{-\frac{1}{2}\,y^2}\,d\,y\Rightarrow -e^{-u}=\int e^{-\frac{1}{2}\,y^2}\,d\,y+C\Rightarrow -e^{t+\frac{1}{2}\,y^2}=\int e^{-\frac{1}{2}\,y^2}\,d\,y+C\Rightarrow -\frac{1}{x}\,e^{\frac{1}{2}\,y^2}=\int e^{-\frac{1}{2}\,y^2}\,d\,y+C
yielding to
x=-\frac{e^{-\frac{1}{2}\,y^2}}{\int e^{-\frac{1}{2}\,y^2}\,d\,y+C}
i.e. coomast's solution. :smile:
EDIT:
x(y)=\frac{e^{-\frac{y^{2}}{2}}}{\int{e}^{-\frac{u^{2}}{2}}du
Okay, an old Latex error finally rectified..
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
