How Close Can Alpha Particles Get to a Gold Nucleus in Rutherford's Experiment?
  • Thread starter Thread starter fatboy12341
    Figure
In Rutherford's gold foil experiment, alpha particles with a charge of +2e and kinetic energy of 7.7 MeV are directed at gold foil, which has a nucleus containing 79 protons (+79e). The discussion revolves around calculating the closest distance an alpha particle can approach a gold nucleus when coming head-on. Participants question the validity of the equations used and seek clarification on the relationship between kinetic energy and closest approach distance. The conversation emphasizes the need to understand the electric potential energy at closest approach and its connection to the alpha particle's kinetic energy. Accurate calculations and the correct application of principles are essential for determining the closest distance in this experiment.
fatboy12341
in a rutherford gold experiment, alpha particles with sharge +2e and a kinetic energy of 7.7 Mev were beamed at gold foil. the nuclius of a gold atom contains 79 protons, giving it a charge of +79e. What is the closest distance that an alpha particle can get to a gold nucleus when it approaches head on ?
ok i used the equation En=k^2 x e^4 me . Z^2
2xh^2 h^2
i am getting n^2= -9.07x10^21
i know this is wrong and am getting quite frustrated
if some on could help me it would be great
can some one tell me if i am eve using the right formula\
We don't know the distance of the alpha particle source with the gold sheet?
2xh^2 h^2
I am not sure what you are doing here. Can you explain what the principle is here? How is the kinetic energy of the alpha particle related to the closest distance between the alpha and the gold nucleus? What is the kinetic energy of the alpha particle when it is at the closest distance? Where did the energy go?
AM
Adding to AM's questions, what is the electric potential energy of the alpha particle at its closest approach, and how is it related to the alpha particle's kinetic energy?
  • · Replies 17 ·
15K
