How to safely charge and discharge a capacitor in a camera?
  • Thread starter Thread starter GiTS
    Capacitor
Charging a 330V, 150uF capacitor with a 9V battery will only charge it to 9 volts, which is insufficient for its intended use. It's safe to leave the capacitor connected to the battery, but doing so while shorting the capacitor can damage the battery. The discharge current is influenced by the capacitor's internal resistance and the resistance in the discharge path; a resistor value should be chosen to prevent damage during discharge. The camera's circuitry is necessary for elevating the battery voltage to charge the capacitor effectively. Extreme caution is advised due to the lethal voltage of the capacitor, making it crucial to have knowledge of high voltage safety before proceeding.
GiTS
I have a capacitor from a camera. It is rated at 330v 150uF. I want to charge this capacitor with a 9volt battery. It would be preferable if I could leave the battery attached to the circuit until the cap is discharged. I want as much power to flow out during discharge as the cap can handle.
What value of resistor for charging is safe but provides for a quick charge?
Is it OK to leave the battery attached to the cap for longer than is needed to charge?
How much resistance should be in the circuit during discharge to prevent damage to the cap?
Thank you,
-GiTS
If you charge this capacitor directly from a 9 volt battery, it will only charge to 9 volts.
150 uF is not a very big capacitor so if you shorted it out after charging, you would just get a small spark.
The discharge current depends on the internal resistance of the capacitor as well as the resistance in the discharge path.
It is OK to leave the capacitor across the 9 V battery, but shorting the capacitor while the battery was there would also short the battery and this may reduce the life of the battery if it persisted for more than a second or so.
That raises a few questions.
1. Why was a 330v capacitor in a camera with a 12v battery?
2. That cap makes a flash go off, are there other parts helping out the flash?
3. I want to launch my estes with this cap, will it be enough to power an estes ignition?
There's a circuit in the camera that elevates the battery voltage to maybe 300 volts to charge the capacitor.
Yes, you need the entire camera flash circuitry. It has a DC/AC converter, a step-up transformer, and a rectifier which turns the AC 300V back into DC to charge the capacitor.
DANGER, BE WARNED. The capacitor voltage is lethal. It's more unsafe than playing around with 120VAC line voltages. You can zap yourself very badly, and perhaps trigger some lethal heart fibrillation.
You can get the strobe charger circuitry out of a cheap disposable camera. ALso I think these entire devices are commonly sold by surplus mail-order. But DON'T mess with these unless you already know how to use high voltage without killing yourself.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
