Capacitor in AC Circuit: Understanding Current Flow and Energy Storage
When a capacitor is connected to an AC circuit, it does develop a potential difference (pd) across it and stores energy in the electric field between its plates. The voltage across the capacitor lags the current by up to 90 degrees, depending on the capacitor's quality. Although the AC current changes direction frequently, the electric field also reverses, allowing the capacitor to continuously charge and discharge. This process does not cancel out the effects; instead, it enables the capacitor to store and release energy effectively. Understanding these principles is essential for grasping the behavior of capacitors in AC circuits.
ay2k
Hello.
When a capacitor is connected in a circuit with an ac supply, a current flows in the circuit. fine. The problem is, does a pd develops across that capacitor, and does it store energy. As in does it "Charge" up?
oh sorry, this thread shouldn't have been here.
But still, anyone?
Yes. No. Yes. No. Yes. No...:smile:
ok now...comeon...:P
say it clearly, I am too dumb to understand your joke...
Yes or no?
Yes, there will be an ac Voltage across the capacitor. Depending on the quality of the capacitor, the Voltage will lag the current by up to 90 degrees.
so will it store energy?
since w=1/2 cv^2
A capacitor does store energy, but it is stored in the electric field between the plates. As the charge builds up on the two plates, a potential difference, and hence an electric field, is generated between the plates. To put more charge on the plates an emf must do work against this electric field and it is this work which is 'stored' as energy in the field.
Do you follow?
ok so what about AC current which changes direction 50 times every second?
The direction of electric field has to change also...
So will it constantly cancel each other's effect or what?
Here's a nice reference on http://www.physclips.unsw.edu.au/jw/AC.html#capacitors" .
thankyou.
That was helpful.
  • · Replies 50 ·
14K
  • · Replies 16 ·
