How Does Capacitor Power Dissipation Impact AC Circuit Behavior?
Capacitors in AC circuits charge and discharge based on the signal frequency, with impedance influenced by both frequency and capacitance. They do not dissipate power but instead absorb and release it, raising questions about energy management when there is no discharge path. The discussion highlights concerns about current flow in transformers when capacitors are involved, particularly regarding initial charging and inefficiencies. It is noted that an ideal capacitor retains charge when disconnected, potentially delivering a shock, which illustrates its energy storage capability. Understanding these dynamics is crucial for effectively managing capacitive loads in transformer circuits.
rebeka
I'm having a really hard time wrapping my head around this. A capacitor in an AC circuit will charge and discharge with respect to the frequency of the signal voltage. Impedance in the circuit is proportional to this frequency and its capacitance. In a power supply the current is regulated through the discharge cycle. What happens to the energy when there is no place to discharge to? Just a capacitive load...
"This means that a capacitor does not dissipate power as it reacts against changes in voltage; it merely absorbs and releases power, alternately. " Does this statement mean that all ESR and leakage inefficiencies aside there will be no current in the primary of the transformer beyond the initial charging of the capacitor?? If this is the case what are the considerations for capacitive loading of a transformer just the initial spike and the inefficiency resistances of the capacitor and transformer? Does the current through the secondary still limit the capacitive load capabilities??
I'm having a hard time parsing your post, but I believe that, if you were to charge up an (ideal) capacitor, and then disconnect it from the circuit, it'd just sit there waiting to zap the next unwitting victim (yes, we did this with small electrolytics and voltages in undergrad labs--even though the charge is dissipating, there was enough charge to give a small jolt). Many digital cameras use supercapacitors as a make shift battery to keep your settings / pictures while you change your main batteries.
See also: Leyden Jar:
http://en.wikipedia.org/wiki/Leyden_jar
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
