Capacitors -- charging and discharging
  • Level: Undergrad
  • Thread starter Thread starter Hannah7h
    Capacitors Charging
13 replies · 3K views · last reply
Hannah7h
So, is this true for when a capacitor charges through a fixed resistor (as shown in the image below, when the switch is closed to 1)- the potential difference across the resistor exponentially decreases to zero and the potential difference across the capacitor exponentially increases from zero to equal the voltage across the battery (power supply), when the capacitor is fully charged?
Yes.
cnh1995 said:
Yes.
Ok, so now if the switch is moved to position 2 and the capacitor is now discharging. The potential difference of the capacitor will now decrease exponentially, and so does the potential difference across the fixed resistor- why does the p.d across the fixed resistor also decrease?
Also, when switch is in position 1, you could say voltage across the cap rises asymptotically to battery voltage.
When switch is in position 2, you can then think of the capacitor as a power supply -- where the voltage drops as you draw current out of it.
Capacitor acts as a source while discharging and voltage across capacitor is equal to the voltage across resistor. Since capacitor voltage is decreasing, voltage across the fixed resistor is also decreasing.
In other words, resistor does not store any charge. Hence, voltage across the resistor decreases while discharging of the capacitor.
Ohhh I see that makes sense, just one more question why in: VC= -VR is the p.d across the resistor quoted as a negative value?
Ah ok yes this makes sense now
It follows from KVL i.e. Vc+Vr=0. Going along the direction of current, you'd see a drop in potential across the resistor and a gain of potential across the capacitor.
Ok yeah makes sense, so when the capacitor is discharging the p.d across the capacitor increases so the p.d across the resistor decreases in order to = zero. And then when the capacitor discharges VC= -VR as both the p.d across the capacitor and p.d across the resistor decrease to zero.
Hannah7h said:
Ok yeah makes sense, so when the capacitor is discharging **charging** the p.d across the capacitor increases so the p.d across the resistor decreases in order to = zero
Right.
cnh1995 said:
Right.
Sorry my mistake! and ok good, thanks for the help!
You're welcome!
Rises exponentially is the correct and precise term!
'Asymptotically' is unnecessary and misleading.
Some 'asymptotic' curves are not exponential.
If the charging/discharging curves of capacitors were described as 'asymptotic' in an exam answer it would be marked wrong !
Take care with terminology!
