• Support PF! Buy your school textbooks, materials and every day products Here!
Capillary height
  • Thread starter v_pino
Given the following information, derive and expression to calculate the capillary depression of mercury in a glass tube given that:
Contact angle = 140 degrees
Surface tension 'Gamma' = 0.476 Nm^-1
Tube diameter = 1.0mm
Density of mercury 'rho' = 13.58x10^3 kgm^-3 (ie. >> 'rho_0')
I've derived the following equation for capillary, which I think is correct:
[tex]
h=\frac{2\gamma cos \theta}{g(\rho -\rho_0)R}
[/tex]
So 'h' is the height of the mercury above the base of the tube.
But this gives me h= -1.095x10^-5 m. This doesn't seem like a correct value for 'h' even if I take it as possible, because it's even smaller than the tube diameter.
Also, the equation was derived by taking 'h' as the height from base to bottom of meniscus. I'm guessing the capillary depression is the distance between the bottom of the meniscus and the maximum height of the fluid (ie. radius of the meniscus). How do I calculate this using the equation I derived? I can only get 'h'.
Answers and Replies
CAF123
88
Since you measured h relative to the base of the meniscus and mercury is depressed within the capillary, the negative makes sense, although I think the result is more negative than the number you got.
haruspex
Insights Author
5,445
It's not, in general, the height above the base of the tube. It's the height above where it would have been were there no surface tension. E.g. if you push a narrow tube down into the surface of a wide reservoir of liquid, it tells you how much higher the level will be inside the tube than outside.
Why does that bother you? The narrower the tube the bigger the effect.
Related Threads on Capillary height
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
13K
