Car A is starting from rest and accelerating at 4.0 m/s^2, car B passes it
Car A accelerates from rest at 4.0 m/s², while Car B travels at a constant speed of 28 m/s. To determine when Car A catches up to Car B, the equations of motion for both cars are set equal. The resulting equation simplifies to 2t² - 28t = 0, leading to a solution of t = 14 seconds. The calculations and the final result are confirmed to be correct.
dasz
Car A is starting from rest and accelerating at 4.0 m/s^2, car B passes it, moving at a constant speed of 28 m/s. How long will it take car A to catch up with car B.
d=Vot+1/at^2
Using the equation above, I used it for car A then car B and made them equal to each other. Got 2t^2 - 28t = 0 then solved. I got t= 14s.
Are there any mistakes? Thanks so much.[/B]
Your equation and result look fine.
