Car traveling away from you and turns the lights on, speed of light
The speed of light remains constant at c, regardless of whether a car is moving towards or away from an observer. When the car approaches, its emitted light experiences blue-shifting, while red-shifting occurs if it moves away. This phenomenon illustrates that light's speed is invariant, even at relativistic speeds. The discussion also touches on how measurements of time and space change according to the Lorentz transform, which accounts for effects like time dilation and spatial contraction. Overall, the speed of light is a fundamental constant in the universe, unaffected by the motion of the source.
nitai108
If a car is traveling towards you and turns on the lights the speed of light would be c, but if the car was traveling away from you and turned the lights on would the speed of light be c or less than c?
I've tried to search this question, but it's not easy to describe in a search engine!
Science news on Phys.org
The speed of light is always c. Regardless if the car is moving towards you or moving away from you, even if the car is moving at 99.9999999...% of the speed of light.
Because light can only slow down if it passes through objects (such as air or glass) but in the vacuum it's always c, right?
Yeap.
Thanks!
C is a fundamental constant of the universe and is always measured as having the same value> If your car turns its lights on and moves towards you at near lightspeed then it wil be moving nearly as fast as the light it is emitting and the light will be dramatically blue-shifted as more wave crests reach you per second than if it were standing still relative to you. If it were moving away from you then its light would be red-shifted but in both cases it would be traveling at c.
What this tells us is that neither metres nor seconds are constants, but change according to the Lorentz transform which describes time dilation and spatial contraction due to motion, a fact which is often mis-ascribed to Einstein.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
