Cauchy problem/characteristics method with initial condition on ellipse
The discussion focuses on solving the PDE xu_x + y u_y = 4u with the initial condition u = 1 on the ellipse defined by 4x^2 + y^2 = 1. The characteristic curves are expressed in parametric form, leading to the equations x(t,s) = s e^t, y(t,s) = ±√(1 - 4s^2)e^t, and u(t,s) = e^{4t}. To find u(x,y), the challenge lies in inverting these equations to solve for t in terms of x and y. The final result shows that t can be expressed as t = 1/2 ln(y^2 + 4x^2), leading to the solution u = e^{2 ln(y^2 + 4x^2)}. The discussion concludes with the successful derivation of the solution based on the initial conditions.
math2011
Consider the PDE xu_x + y u_y = 4 u, -\infty < x < \infty, -\infty < y < \infty. Find an explicit solution that satisfies u = 1 on the ellipse 4x^2 + y^2 = 1.
x(t,s) = f_1(s) e^t
y(t,s) = f_2(s) e^t
u(t,s) = f_3(s) e^{4t}.
The initial conditions are
x(0,s) = s
y(0,s) = \pm \sqrt{1 - 4s^2}
u(0,s) = 1.
Parametric representation of the integral surface is then
x(t,s) = s e^t
y(t,s) = \pm \sqrt{1 - 4s^2} e^t
u(t,s) = e^{4t}.
How do I invert these to get u(x,y)?
Since u(t,s)=e^{4t}, you need only solve for t=T(x,y) in the system:
x=se^t
y=e^t\sqrt{1-4s^2}
then:
u(x,y)=u(T(x,y))=e^{4T(x,y)}
I'll start it for you:
y^2=e^{2t}(1-4s^2)
but from the first equation:
s^2=x^2e^{-2t}
now you finish it to find t=T(x,y). Not sure about the \pm though on y.
Thank you. I got t = \frac{1}{2} \ln (y^2 + 4x^2) and hence u = e^{2 \ln(y^2 + 4x^2)}.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
