Cauchy Sequences and Convergence
41 replies · 7K views · last reply
Seth|MMORSE said:
##M>N_1## that you defined? I have the feeling that I have to start learning analysis from scratch again ...
Maybe so. This is like pulling teeth. I have already given more help than I should on this forum.
That will make ##p<\epsilon/2##. You need both p and q to be less than ##\epsilon/2##. How big does M need to be so that if ##n>M## they both work? You should be able to figure that out.
Since for ##n>N##, we are able to get ##|b_n-a|<\epsilon## ...
Therefore, if ##n>M\geq N, |b_n-a|<\epsilon##
Therefore, if ##n>M\geq N##, ##|b_n-a|<\epsilon##
But maybe ##M## isn't greater than ##N##.
[Edit] I am not going to be satisfied with your answer until you have something like:
Let M = ______. Then if ##n>M## both p and q are less then ##\epsilon/2##.
Therefore it should be there exists an ##M\geq N## such that ##|b_n-a|<\epsilon\ \forall n>M##?
##M=\frac{a_1+a_2+...+a_M}{\epsilon+a}##?
From equating ##\epsilon## and ##b_M-a##
No. The best I can do without giving you the answer, which I'm not going to do, is tell you to re-read post #25. You are stuck on a really easy issue, unfortunately.
I don't see anything in post #25 :confused:
I'm can't help it that my brain doesn't know what to look for, just staring at it over and over again without seeing anything different ... sigh
In post #24 you had, among other things:
Seth|MMORSE said:
##|b_n-a|##
##= |\frac{a_1+a_2+...+a_n}{n}-a|##
##=|\frac{a_1+a_2+...+a_n-na}{n}|##
##=|\frac{(a_1-a)+(a_2-a)+...+(a_n-1)}{n}|##
By triangle inequality,
##\leq |\frac{a_1-a}{n}|+|\frac{a_2-a}{n}|+...+|\frac{a_n-a}{n}|##
##=\underbrace{(|\frac{a_1-a}{n}|+...+|\frac{a_{N}-a}{n}|)}_{p}+
\underbrace{(|\frac{a_{N+1}-a}{n}|+...+|\frac{a_n-a}{n}|)}_{q}##
##p=|\frac{a_1-a}{n}|+...+|\frac{a_{N}-a}{n}|##
##=\frac{1}{n}(|a_1-a|+...+|a_{N}-a|)##
We define ##n>\frac{2(|a_1-a|+...+|a_{N}-a|)}{\epsilon}##
##\frac{1}{n}(|a_1-a|+...+|a_{N}-a|)<\frac{\epsilon}{2}##
##\Rightarrow p<\frac{\epsilon}{2}##
To which I responded in post #25:
Much clearer to let ##N_1=\frac{2(|a_1-a|+...+|a_{N}-a|)}{\epsilon}## and say:
if ##n>N_1## then ##p<\frac{\epsilon}{2}##
You also had in post #24 this:
##q=|\frac{a_{N+1}-a}{n}|+...+|\frac{a_n-a}{n}|##
Using ##|a_n-a|<\frac{\epsilon}{2}\ \forall n>N##
##q<\frac{\epsilon/2}{n}+...+\frac{\epsilon/2}{n}##
##=(\frac{n-N}{n})(\frac{\epsilon}{2})##
##=(1-\frac{N}{n})(\frac{\epsilon}{2})##
Since ##n>N, (1-\frac{N}{n})<1##
##(1-\frac{N}{n})(\frac{\epsilon}{2})<\frac{\epsilon}{2}##
##\Rightarrow q<\frac{\epsilon}{2}##
So if ##n>N## then ## q<\frac{\epsilon}{2}##
Then you concluded that
##|b_n-a|=p+q##
##|b_n-a|< \frac{\epsilon}{2}+\frac{\epsilon}{2}=\epsilon##
That conclusion is only valid if both p and q are less than ##\epsilon/2##. Look at the statements I highlighted in red. How large does M need to be to make both statements true if ##n>M##?
##M=max(N,N_1)##?
I kept thinking of using inequalities ...
Seth|MMORSE said:
##M=max(N,N_1)##?
There now. That wasn't so hard, was it? I hope you have learned a few things about ##\epsilon,N## proofs in this thread. So you will just breeze through your next such problem. :wink:
NONE of my previous exercises required me to use such a function ... never occurred to me ... till something struck.
Anyway, thank you so much for your help!
