I Center of Mass Motion: Velocity & Momentum
Hiero
If we have a system of masses in motion, will the velocity of the center of mass always be given by the net momentum divided by (1/c^2 times) the total energy of the system?
Center of energy, but yes. As long as you do not subject it to external forces.
For motions restricted to one spatial dimension, it's easy enough to show. For more dimensions of space things get messier. I am working straight from the definitions though; maybe there is some 4vector approach?
Nevermind; the way I was doing it was unnecessarily difficult... We can just use the lorentz transforms of energy E and momentum P:
If we boost out of the center-frame where P=0 then the new energy will become ϒE and the new momentum will be ϒvE/c^2 and hence the velocity of the center-frame (v) will be given by c^2(P'/E')
(The linearity of the transformation means it doesn't matter if we're talking about a single particle or the sums of many.)
It is actually not that simple unless your particles are non-interacting. The reason for this is relativity of simultaneity. You generally need to work with the energy momentum tensor.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
