Centrifugal Force on a stone tied to a thread
The discussion revolves around the concept of centrifugal force as it relates to a stone tied to a thread and spun in a circular motion. Participants explore the implications of centrifugal force in inertial and non-inertial frames, the nature of forces acting on the stone, and the dynamics of objects on a frictionless disk. The conversation includes theoretical considerations, conceptual clarifications, and some debate over terminology and interpretations of Newton's laws.
  • Some participants express confusion about centrifugal force and its role when a stone tied to a thread is spun in a circle, questioning which force causes the stone to fly off tangentially when the thread breaks.
  • Others argue that from an inertial frame, no centrifugal force is needed to explain the stone's tangential motion, attributing it to inertia as described by Newton's first law.
  • There is a discussion about the centripetal force exerted by the string on the stone and the reactive outward force the stone exerts on the string, with some participants referring to this as a reactive centrifugal force.
  • Some participants assert that all forces acting on the stone and string are directed toward the center of rotation, while others challenge this by stating that the stone exerts an outward force on the string.
  • A participant mentions that on a frictionless disk, the object will not slide outward but will remain in place, prompting further debate about the nature of forces in this scenario.
  • There is contention regarding the terminology used to describe forces, with some participants emphasizing the distinction between net forces and general forces in the context of the discussion.
Participants do not reach a consensus on the role of centrifugal force, the nature of forces acting on the stone and string, or the behavior of objects on a frictionless surface. Multiple competing views remain, and the discussion is characterized by ongoing debate and clarification.
Participants express varying interpretations of Newton's laws and the definitions of forces, leading to unresolved questions about the dynamics involved in circular motion and the implications of centrifugal force in different frames of reference.
Cromptu
I am not sure I get the concept of centrifugal force..
If we have a stone tied to a thread and we just spin it in a circle, and while we are spinning it in a circle, the thread breaks and the stone flies off tangentially.
If we watch this motion from an inertial frame, which force will be responsible for making the stone fly of tangentially? Since, when seen from an inertial frame, there is no centrifugal force..
Another case could be :
An object is placed on a frictionless disk and the disk is rotated about its axis with some velocity. When we see the motion of the object from an inertial frame, we will see that stone first slides to the end of the disk and then flies off tangentially ( right? since there is no friction )
Again, which force will be held responsible for this motion? Could it be centrifugal force? I've learned that centrifugal force is a pseudo force used to validate Newton's equations when we see the motion of an object from a non- inertial frame.
So which force is responsible for this tangential motion?
Forces are needed to change the velocity of an object. (That's why you need a centripetal force to keep something moving in a circle.) No force is needed to make something fly off tangentially--it's just inertia in action, Newton's 1st law.
Looked at from an inertial frame there is no need for any centrifugal pseudo force when something moves in a circle.
Tangental motion implies a straight line, so no force is required (at least no lateral force) for straight line motion.
As far as the terminology, the string exerts a centripetal force on the rock, and the other part of the Newton third law pair is: the rock exerts a reactive outwards force on the string as a reaction to the centripetal acceleration, sometimes called a reactive centrifugal force, which is a real force in a inertial frame. Wiki article:
http://en.wikipedia.org/wiki/Reactive_centrifugal_force
Cromptu: Doc Al is right. There is no centrifugal force acting on the stone. There is no force that accelerates the rope outward either. All forces are toward the centre, including the force on the person causing holding the other end of the rope.
In order to swing that rock you have to lean in the opposite direction - outward from the actual centre of rotation. Both you and the rock rotate about the centre of rotation. Everything accelerates toward the centre. Nothing accelerates away from the centre.
Cromptu said:
An object is placed on a frictionless disk and the disk is rotated about its axis with some velocity. When we see the motion of the object from an inertial frame, we will see that stone first slides to the end of the disk…
No, if it's frictionless, the object will stay where it is. :wink:
There are no outwards accelerations, but the rock exerts an outwards reactive force on the string (the outwards reactive force is in response to centripetal acceleration of the rock by the string).
There are certainly tensions in the string as there are throughout the stone and the person at the other end of the rope. The tensions are not balanced, however, as there is a net acceleration of every part toward the centre.
AM
Thanks a whole lot! I've finally got it! :D
Nope. The force by the stone on the string points outwards.
Andrew Mason said:
acceleration
Irrelevant, as long you talk about forces in general, not specifically net forces.
And there are forces on atoms in the stone going sideways, up and down etc. But they don't accelerate anything. We don't care about those forces because they don't do anything. The net forces on all parts of the rope and stone and person are toward the centre of rotation.
I was distinguishing tensions from forces (F=ma). The tension differences on each atom = F = ma. This is what gives each atom its acceleration toward the centre.
AM
It's not for you to decide about which forces someone cares. If string and stone are mentioned as separate objects, then there are equal but opposite forces between them in a free body diagram.
If you mean 'net forces' then write 'net forces'. Using the more general term 'force' is wrong here.
If the forces on the rope and the the stone were equal and opposite there would be no acceleration, which is not the case. There are other forces on the rope. You might care about the just the forces of the connecting molecules of the rope and stone. But a student interested in the physics of rotating systems is trying to understand the (net) forces that cause centripetal acceleration. That is why often these kinds of problems treat the rope as "massless": because we care only about the forces between the objects at the ends of the rope.
In the case of bodies, A and B, tethered by a rope of negligible mass and rotating about their centre of mass, we can say that the force of A on B is equal and opposite to the force of B on A and that both forces are directed toward the centre of rotation. There is nothing incorrect about that.
It is true that the tensions within A result in the surface of A pulling on the molecules at one end of the rope and the resulting chain of various tensions between molecules of the rope causes the molecules on the other end of the rope to exert tensile forces on the molecules on the surface of B and through tensile forces throughout B to accelerate all the molecules of B.
It is just easier, and much clearer to the poor student, to say that A and B exert centripetal forces on each other via the rope.
AM
Are you saying that the force that the stone exerts on the rope is not equal and opposite to the force that the rope exerts on the stone? (In direct violation of Newton's 3rd law.)
I am saying that it is correct to say, in my example, that A exerts a force on B by means of the rope, and B exerts an equal and opposite force on A and both forces are directed toward the centre of rotation. If you want to examine the forces between the stone and rope you have to look at what the rope is connected to. If it is connected to nothing, there is no force on the rope and the rope exerts no force on the stone. If it is connected to something, the force on the rope and the rope on the stone depends on what is at the other end of the rope.
In my view, we should not confuse students by introducing a useless and misleading concept of a "real" centrifugal force. This is not a concept taught in many physics texts. When it has been mentioned in a text (eg.Delo E. Mook & Thomas Vargish (1987). Inside relativity) it is wrong (the statement that the Earth exerts a centrifugal reaction force on the sun). Even the Wikipedia page (http://en.wikipedia.org/wiki/Reactive_centrifugal_force ) is wrong (eg. centrifugal clutch is an example of the pseudo centrifugal force as it is the inertia of the rotating parts of the clutch that cause the clutch to engage, not an outward accelerating force). Are you aware of a reputable text that even mentions it?
AM
Nonsense. The equal but opposite forces don't cancel, because they act on two different objects: inwards force acts on the stone, outwards force acts on the rope. You have a classic freshman misconception about the 3rd Law, often explained with the horse and cart:
http://www.lhup.edu/~dsimanek/physics/horsecart.htm
Andrew Mason said:
...introducing a useless and misleading concept "real" centrifugal force.
Nobody is introducing a new concept here. It is just consequent application of Newtons 3rd Law.
Doc Al asked you about the 3rd Law force pair between rope and stone. Why do you obfuscate instead of answering his question?
You have to read what I said. I said "If the forces on the rope and the stone were equal and opposite there would be no acceleration, which is not the case. There are other forces on the rope.". I am referring to all the forces on the stone and on the rope.
Ok. But calling it centrifugal suggests it is a force that causes a fleeing from the centre, which is not true. And it makes it difficult to distinguish it from the fictitious centrifugal force, as the examples in Wikipedia and in the text that I quoted demonstrate.
AM
The forces between the rope and the stone are equal and opposing, a Newton third law pair, but the force the stone exerts on the rope is an (outwards) reaction force to (inwards) acceleration, so it's not a "net" force, but it is a real force (othewise a massless rope would not be under tension).
If you mean 'net forces' then write 'net forces'. But even when corrected, it is still irrelevant - Newtons 3rd applies in general to individual force interactions, not net forces.
The confusion comes from your misguided causation/acceleration reasoning. Newtons Laws don't care about causes. Acceleration is related to net force not just any force.
Andrew Mason said:
"If the forces on the rope and the stone were equal and opposite there would be no acceleration.
Only if those forces act on the same object. In this case, the equal and opposing forces are applied to different objects, the rope exerts an inwards force on the stone, and the stone exerts an outwards force on the rope. The net force on the stone is inwards from the rope (if there's gravity, and the motion is circular at constant speed, the upwards component of tension opposes the downwards force from gravity, so the net force on the stone is still inwards).
I don't get what the issue is here? The rope exerts an inward radial force on the stone and the stone exerts an equal and opposite (i.e. radially outward) force on the rope. It is standard to call the inward radial force on the stone from the rope the centripetal force and some sources will call the outward radial force on the rope from the stone as a reactive centrifugal force, not to be confused with the inertial centrifugal force that arises in rotating frames. So, I ask again, what's the issue?
I suggest some people here stop trying to argue by shouting, and try drawing free body diagrams (including the acceleration!) instead.
If you make this much of a meal of the simplest possible case, circular motion of rigid bodies at constant angular velocity, God help you if you ever try to understand the general motion of flexible bodies!.
If I ever get to be world dictator, my first act will be to execute everybody who has ever used terms like "reactive centrifugal force" as if they actually meant something :biggrin:
There is really no issue other than choosing to call the third law pair to the centripetal force on the stone "centrifugal".
Centrifugal means fleeing the centre (of rotation). There is no way that the third law pair to the centripetal force on the stone can possibly cause any part of the rope to flee the centre of rotation.
I suggest that "centrifugal" should not be used to describe the 3rd law pair to the force on the stone. In my view, it simply adds confusion and makes it even more difficult for students to understand that centrifugal "forces" (ie. those that cause objects to flee the centre of rotation) are really just inertial effects and not real forces.
AM
Oh, well then I agree yes it certainly causes confusion. Thankfully it's not a standard term from what I've seen.
My sentiments exactly.
False. "All net forces" are toward the center in this case, which is not at all the same as "all forces".
The F in that equation is the net force.
This is nonsense. A third law pair act on different objects and they are never summed to determine a second law net force or acceleration.
You should stick with this objection. Your technical objections are flat out wrong. If you don't like a term then you don't need to use it. If it causes confusion or is redundant or has other semantic problems then explain that. But like it or not the term is well defined and the concept has no technical deficiencies. The only possible objections are semantics and personal preferences.
I did not say otherwise. See my response in post #17. My comment was in response to A.T.s statement: "If string and stone are mentioned as separate objects, then there are equal but opposite forces between them in a free body diagram." I was not objecting to that statement. I was just saying it was incomplete. There are other forces on the rope (ie. that you would have to show in a free-body diagram). If there were not, you could not have the (centripetal) acceleration that is observed.
I disagree. "Centrifugal" has significant technical deficiencies. There is no possible way that the third law pair to the centripetal force on the stone will ever cause the rope to flee the centre of rotation. You have only to look at the Wikipedia article on "centrifugal reaction force" to see the confusion that surrounds that term.
AM
It is complete, as far Newtons 3rd is concerned. Your deflections about accelerations are just conflation of forces and net forces.
Irrelevant from the technical standpoint. Newtons Laws don't care about causes. Acceleration is related to net force not just any force. As DaleSpam said, it is just semantics and personal preferences.
As far I can say this is the core of the issue:
Confusion of "force" and "net force" (as in F=ma). All the other wrong claims follow from that: That there are no outward forces, because there is no outward acceleration. That action & reaction in Newtons 3rd must be actual accelerations. And so on.
:smile: :approve:
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 114 ·
  • · Replies 23 ·
