member 529879
How exactly does the centrifugal force work? What causes it? Why is it considered a fictous force?
The discussion clarifies the concept of centrifugal force, describing it as a fictitious force that arises in rotating reference frames. It explains that while objects in a stationary frame continue in a straight line due to inertia, observers in a rotating frame perceive a force pushing objects outward, termed centrifugal force. This force opposes the centripetal force, which is necessary to keep objects in circular motion. The conversation also highlights the role of static friction in providing centripetal force and introduces D'Alembert's Principle as a key concept for understanding inertial forces.
PREREQUISITESPhysics students, educators, and anyone interested in the mechanics of motion and forces in rotating systems will benefit from this discussion.
Did you read that?Scheuerf said:How exactly does the centrifugal force work? What causes it? Why is it considered a fictous force?
The velocity is always tangential to the circle, so the bend in the velocity (the acceleration) is always toward the center. To make a free object take that turn, and not fly away straight, you must apply a centripetal force. That centripetal force is opposing the centrifugal force that tries to make the object fly away (actually just go straight away at the tangent velocity)Scheuerf said:Okay it's starting to make more sense now, but how is it that it points opposite the centripetal force and not in the direction of motion?
To make Newtons 2nd law work, as explained in post #3.Scheuerf said:Okay, I understand now that the centrifugal force opposes the centripetal force. But why exactly?
The inertial centrifugal force (in a rotating frame) acts on all objects, even those on which no real centripetal force is acting.ulianjay said:Centrifugal force is an inertial force that results from the change in momentum created by the centripetal force.
A.T. said:The inertial centrifugal force (in a rotating frame) acts on all objects, even those on which no real centripetal force is acting.
Objects in rotating reference frames can have arbitrary accelerations, which are not necessarily centripetal.ulianjay said:In a rotating reference frame all objects are by definition subjected to a centripetal acceleration.
