Centripetal Acceleration check my reasoning
4 replies · 2K views
pointintime
ok well then...
we did a lab were you have a hanging mass attached to a stirng that went through a straw and was attached to a rubber stopper. The lab was to find the mass of the rubber stopper once you know the velocity. So I was woundering if this looks correct
f = ma
m1 = mass of stopper
m2 = mass of hanging mass
radial acceleration = r^-1 v^2
net force radial = m (acceleration radial) = force of gravity on mass m2
net force radial = (m1 + m2) (acceleration radial) = m2 g
net force radial = m1(acceleration radial) + m2 (acceleration radial) = m2 g
net force radial = m1(acceleration radial) = m2 g - m2 (acceleration radial)
divided both sides by acceleration radial
m1 = (acceleration radial)^-1 ( m2 g - m2 (acceleration radial) )
at which point I plugged in the value I found for the radius
the value I found for the period
and found the radial acceleration
ok hmmm
m2 g = m1 (acceleration radial)
so then if this is the correct equation my question... is how do you know when to consider the masses as a system and when not to?
net force = mass times acceleration
by deffintion
it dosen\'t mean this necessarily
net force = net mass times acceleration
when do I know when I should use the net mass and when not to as I have gotten points taken off before because i didn\'t use the net mass and am not sure when to consider the masses as one system and when not to...
like how come this is wrong
net force radial = (m1 + m2) (acceleration radial) = force of gravity on m2
and this is right
net force radial = m1 (acceleration radial) = force of gravity on m2
I need help on when to make this distinction between the masses and when not to as I don\'t know when i should...
THANKS!
This has been eating me away and I need to know this or the whole problem is wrong so it\'s important that I know when to make this distinction and when not to. So can you tell me when I should and when I shouldn\'t?
M1g = Msv^2/r
M1 was your known mass hanging. g is the acceleration due to gravity. Ms is the mass of your rubber stopper. v is the speed of your rubber stopper and r was the length of the string from the straw to the rubber stopper (the radius of the circle the rubber stopper was making around the straw)
I guess you counted how many times it took to make a certain number of revolutions in a certain amount of time. 1 rev. =2 x pi x r. Divide the number of revolutions by the time in seconds it took to make those revolutions and you got v. At this point you know everything but Ms so put all the numbers in and solve for Ms
Could you please give me your data:
Mass of the object hanging from the string.
radius of the circle the stopper was making while holding the mass at rest below the straw.
How many times the stopper went around and in what amount of time.
