Centripetal acceleration geometry
3 replies · 4K views · last reply
richardbsmith
This is probably a geometry question more that a physics question. I am trying to prove that in uniform circular motion [tex]\Delta[/tex] V[tex]/[/tex]V= s[tex]/[/tex]R.
I am basically trying to show that S forms a right triangle with [tex]\Delta[/tex]V, when [tex]V{1}[/tex] is added to [tex]V{2}[/tex] as a vector. (This is to demonstrate that the triangles are similar.)
I understand that the angle formed by S and [tex]\Delta[/tex]V is a right angle because it obviously inscribes the diameter. I just cannot seem to find a satisfactory proof that [tex]\Delta[/tex]V must necessarily intersect the circle at the diameter.
Probably not explaining this very well.
If you are solving geometry problems with both distances and velocities involved, then you
are probably making a mistake: remember that they have different units! (unless you study relativistic theory)
For the mentioned problem you should use formulas:
s=R*fi (fi is angle of the part of orbit traveled in radians)
[tex]\Delta[/tex]V=V*sin(fi') (fi' is the angle between the old and new velocity vector)
Prove that fi=fi' and use sin(fi)=fi (for small angles) and you will get [tex]\Delta[/tex] V[tex]/[/tex]V= s[tex]/[/tex]R
Thank you so much for responding. I think though my question which started with uniform motion and delta V, is now simply a geometry question.
I will try to put up a drawing of what I so pitifully tried to explain.
Geometry diagram of a circle with two tangent lines drawn in blue, labelled 1 and 2 by red arrows, with radii in red and green connecting the tangent points to the centre and to each other.
Here is another image with a different angle and size of the tangents.
Geometry diagram of a circle with a horizontal diameter, a point on the circle at the top with two straight lines from it, and two blue vertical connectors at right angles to tangent lines drawn at the diameter ends and the upper point, with red lines marked 1 and 2.
I have tried several approaches, but I cannot prove that the angle formed from tangent 1 to tangent 2 to the circle must inscribe a 180 degree arc and must be a right angle.
From : http://en.wikipedia.org/wiki/Inscribed_angle_theorem
In geometry, the inscribed angle theorem states that an angle θ inscribed in a circle is half of the central angle 2θ that subtends the same arc on the circle.
So, to get an inscribed angle of 90° you need a central angle of 180°(=diameter line).
