Calculating Centripetal Force: Diagramming and Solving for X and Y Forces
Centripetal force can be expressed as F=(mv^2)/r, which can be demonstrated through diagramming and analyzing the forces in the x and y directions. The work done by centripetal force in the radial direction is calculated as the product of the force magnitude and displacement in the same direction. Since the force and displacement vectors are perpendicular in uniform circular motion, the angle between them is 90 degrees, resulting in zero work done. This means that while centripetal force maintains circular motion, it does not perform work on the object. Understanding these relationships is crucial for solving problems related to centripetal force and motion.
kdburns
How would you go about proving that centripetal F=(mv^2)/r by diagramming and solving for the magnitude of the forces in the x and y direction?
For example, suppose I wanted to calculate the work done in the radial direction by centripetal force.
Thanks so much! Really helpful
Work is the product of the applied force magnitude x the magnitude of the displacement (D) in the same direction as the applied force. As a result, this is sometimes expressed as W = F x Dcosθ where θ is the angle between the two vectors (F and D). Since the F and D vectors are always perpendicular for circular motion of a mass at a constant speed, the angle between the two vectors is always 90°. So, the work done in circular motion at constant speed is 0 since cos90° is 0.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
