Centripetal Force And Acceleration
In the discussion on centripetal force and acceleration, participants clarify that for an object in uniform circular motion, the correct statement is that acceleration is directed towards the center, not outward. There is confusion regarding the centripetal force experienced by a man on a ferris wheel, with calculations showing a net upward force of 70N at the top. The debate centers on the signs of forces, where gravitational force and centripetal force must be considered in the same direction. Misinterpretations arise from the distinction between centripetal and centrifugal forces, leading to differing conclusions about the direction of forces. Ultimately, understanding the signs and directions of these forces is crucial for accurate calculations in circular motion scenarios.
Erwin Schrodinger
1. Which of the following statements best applies to an object moving with uniform circular motion?(Answer: B)
A. Acceleration is zero.
B. Acceleration is directed outward.
C. Acceleration is tangent to the path.
D. Magnitude of acceleration is constant.
I thought the answer was D but how can it be B? Centripetal acceleration is always towards the center of the circular path. How is that outward?
2. A 50kg man is riding a ferris wheel at a constant speed. At the top of the wheel, the seat exerts an upward force of 420N on him. What is the centripetal force on the man at the top of the wheel? (Answer: 70N)
Fnet = FN+Fg+Fc
0 = 420+50(-9.8)+Fc
70N [up] = Fc
Again, this direction has me confused. Centripetal force is always towards the center of the circular path so why am I getting an up answer?
For number two, if you consider mg negative, the upward force is positive. Since mg is directed at the center of the wheel and 50(9.8)>420, thus 420 - 50(9.8)>0. Since it is negative it is directed to the center of the wheel; this is the centripetal force. Your mistake was to consider F_c to be positive, but it is negative since it's in the same direction as mg.
Are you sure that you're transcribing these directly. There's an important difference between centripital acceleration and centrifugal force.
For part 1:
With the question as you have written it, of the choices listed, the only correct one is D.
For part 2:
Are you sure the question is asking for "centripetal" force? The correct answer, to the question as you have it written would probably be "the force of gravity".
However, if the questions were asking about centrifugal force rather than centripetal acceleration, then the answers that are given would make more sense. (Although the magnittude of the centrifugal force is constant for uniform circular motion.)
Yep, I copied these questions exactly as they were stated in my workbook.
Werg22, I don't understand your explanation. I'm saying that positive is up and negative is down. 0 = 420-490+Fc. Fc has to be positive 70N which means its up. I don't think there's anything wrong with the algebra; it just doesn't make sense.
You let F_c and the upward force be of the same sign, which is wrong since F_c is in the same direction as mg and thus mg and F_c need to be of the same sign.
Look:
You start with
F_c = Fnet
F_c = 430 + mg
Since F_c is in the same direction as mg, they are of the same sign
If you consider mg negative, thus Fc is negative.
0= 430 + mg -F_c, Since you multiplied F_c by -1, its sign changes. Your mistake was to consider F_c positive, but it is not since the sign changed. So -F_c = 70, and F_c = -70.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
