Centripetal force demo dishonesty
43 replies · 10K views
d4rr3n
I find physics classroom demonstrations of centripetal force dishonest, they often resort to trickery to demonstrate this apparent "inward pull" on a body in circular motion. Two examples follow
1, Centripetal force "pulling" a candle flame towards the center of a spinning turntable
2, Centripetal force "pulling" cork/bob floating in water towards the center of a spinning
In the first demonstration air is being centrifuged outwards and the displacement of air is causing the flame to point inwards, it is actually being pushed inwards not pulled inwards.
In the second demonstration its the same basic principle, water is centrifuged outwards causing the bob or cork to point inwards.
In actual fact all demonstrations to demonstrate this apparent inwards force have resorted to trickery. We know that in practice there is no inward force if there were our clothes would be projected inwards whilst spinning in a spin dryer, we know that in actual fact the opposite is true.
Is it ok to resort to misdirection and trickery to demonstrate the apparent "inward pull" on a body in circular motion?
This is exactly the same mechanism that causes a stationary candle flame to rise straight up... It's being pushed upwards by the pressure of the air around it being drawn down by gravity.
You'll find a better example in the spin cycle of the washing machine, where the clothes are forced inwards by the basket while the water escapes through the holes in the basket.
I agree the verbal explanations in the first two videos were poor. But the physics doesn't change because it is explained badly.
If you want to understand the candle and fishing float demos better, you can eliminate "rotation" with this experiment. Get a helium balloon and hold it on its string inside a car, so it is free to move in the air. Watch how it moves when the car accelerates and brakes in a straight line, and then how it moves when cornering at constant speed if possible. Close all the windows and air vents and turn off the aircon, to seal up the air space inside the car as much as possible.
The candle flame, fishing float, and balloon are all lighter than the surrounding air or water. That's the reason they appear to move "the wrong way" compared with "common sense".
Frankly, what I find dishonest is misquotes. The video doesn't say that the flame is being pulled toward the center, it says that the air is being pulled into a circle, simulating gravity, making the flame point in the direction it thinks is "up". That descriptions just fine.
The second video says an "object" being pulled toward the center, but glosses over the fact that the "object" in question is the jar full of water, not the bobber. It isn't wrong per se (the sentence sounded straight out of a textbook), it is just not fully explained.
Nothing is in fact being "pulled" towards the center, there is no real pulling force. When a candle burns in normal conditions the reason the flame points upwards is because the hot vapor of the candle is less dense then the surrounding air thus it rises. In the case of the candle put into the centrifuge the air in the bell jar is being compressed (forced to the outside). The air being more dense at the outside the hot vapor expands in the opposite direction. Nothing is being "pulled" inwards, there is no inward pull.
The spin cycle of a washing machine again nothing is pulled inwards towards the center of the drum, both the clothes and water is centrifuged to the outside of the drum.
The only time there is an illusion of the clothes being pulled into the center of a drum is in a tumble dryer when the drum changes direction of rotation however that is due to other factors and again there is no real pull towards the center of the drum.
Only in the non-inertial frame of reference rotating with the drum.
In an inertial frame, there's no centrifugal force, and clothes are most definitely accelerated towards the centre of the drum by the drum walls, as otherwise they'd travel in straight lines as per the Newton's 1st law of motion.
What would be the resultant of the combined vectors, the tangential and the supposed centripetal force added, it would be an inwards spiral and we most definitely do not observe this in a spin cycle of a washing machine.
If we now change the vectors, one tangential as before and the other pointing outwards away from the center of the drum (centrifugal) we have a resultant force which is a spiral outwards ie compressing the clothes against the side of the drum, this fits in reality closer to what we observe.
There is tension in the devices pictured: they most certainly are pulling on the "objects" to keep them in "orbit" around the center.
The drum is arranged so that it pushes the clothes toward the center, but in its structure underneath is tension, pulling the parts of the drum toward the center.
The tension is only in the turntable/rotor between pivot and outer extremity of the mass, tension is caused by an outward force, were it an inward force it would be in a state of compression which again we do not observe
You mean the drum wall is slightly conical? in any case still there is no centripetal inwards force. Look at the last video of the spinning fish tank and state where this inward force is observed.
The wall of the tank exerts a force on the water. In which direction is this force acting?
There is no tangential force. The only tangential vector is that of the tangential velocity, which the centripetal acceleration(via the force) is constantly changing(direction only) to keep the clothes moving in circles. There's nothing to add.
From your description, i.e., the drum is moving rather than stationary, I gather you use an inertial reference frame. In such a frame there is no centrifugal force.
You are dodging your own statement in the OP, not just what I said. You said "inward pull" in the OP and I said "pulling" in my post. The tension means the center is pulling the object toward it and the object is pulling back. Draw a free body diagram if you don't believe it.
No one has said that the object is pushing toward the center. That doesn't even make any sense.
No, I mean the base of the drum is a disk just like the setup in the first video. It is that disk that is in tension.
The base of the fish tank is in tension (edit: so are the sides).
Part of your issue here is that you don't seem to be grasping that all forces come in pairs. The center axis pulls the object towards it (inward) and the object pulls away from the center (outwards).
The walls of the tank "resist" an outward force, if you spin the tank fast enough and had a lid the tank walls would explode. There is no inward push that I can see, the system is in tension not compression.
It doesn't rise just because it is less dense. In zero gravity burning products just stay there, and extinguish the fire.
Either you are truly not seeing this, or you are purposely being difficult and refusing to learn.
Here's a challenge for you. We already have well-known solutions to the central force problem. They are written in books, they are part of students' homework assignment, etc.
Now, if you disagree with this, then please show me the solution for an outward force problem, and derive the same equation of motion that we arrive at for the central force problem. After all, the central force problem has shown ALL the equation of motion that fits very well with our observations. So go ahead, show me that you can actually get the same trajectory and motion of your system with this outward force alone.
Otherwise, this scenario of yours remains nothing more than a misguided handwaving argument.
Zz.
By tangential I am talking about the inertia of the spinning objects that would want to move in a straight line. add that to the inward centripetal and you should have an inward spiral but we don't see this.
Instead let's consider a satellite orbiting the Earth Vs a wagon wheel spinning at high speed.
In the case of the satellite orbiting the Earth we have the inward pull of gravity and the tangential inertia of the satellite curving around the Earth, add those vectors and the resultant is an inward spiral so that eventually the satellite crashes to Earth (lets not get into escape velocity here).
In the case of the spinning wagon wheel are the spokes of the wheel in a state of compression or tension? If they are in a state of compression we can talk about an inward centripetal force but if (and they are) in a state of tension it makes no sense to talk about inward force, tension could only be the result of an outward force (centrifugal).
d4rr3n said:
The walls of the tank "resist" an outward force ... There is no inward push that I can see,
Remember Newton's third law, the one about equal and opposite forces; the "resisting" to which you refer is the centripetal force.
The water directly adjacent to the edge of the tank is in compression from the force the tank wall is exerting on it. The tank wall is in tension from the equal and opposite force the water is exerting on the wall.
Zz.
I truly do not see the inward force, if I did this discussion would not exist. In the case of the fish tank I see the base of the tank in a state of tension (the result of an outward force) and I see the two walls in a state of compression (resisting the pressure exerted by the centrifuged water). I cannot see any inward force
The problem here is that in many of your examples, you are picturing yourself in that rotating frame! You keep talking about the "outward force", which really isn't there when you are not in that frame. It is easy to make that mistake because we all have been in a car when it curves around the corner and "feel" the outward force. But we forget that we want to go in a straight line, and the side of the car and the friction between the seat and our butts provide the inward force that pushes us in.
I suggest you look again at each of your example without trying to picture yourself in the rotating system. Look at what is pulling the objects inwards. It is there! I guarantee it! Your intuition does not match, even remotely, to the mathematical derivation of the equation of motion for a circular motion. That should mean something to you!
Zz.
If we spin the tank and the water mounded up in the center of the tank I would agree it makes sense to talk about an inward centripetal force. However the opposite is true so it makes more sense to talk about an outward centrifugal force pushing the water out from the center.
Which force is more primary, the inward resistive force offered by the walls of the tank you speak of is a reactive force ie a reaction
the outward force is more primary in this situation
You can't add inertia and centripetal force vectors, because inertia is neither a force nor a vector. Momentum is a vector, and the force acts to change it, but you still can't add them together.
The inward spiral in the case of satellites that leads to de-orbit is caused by the drag force of the diffuse molecules of the Earth's atmosphere acting against the satellite's motion. If you eliminate drag(and other such additional forces, like tidal forces), so that the only force acting is the centripetal one(gravity) you end up with an eternal orbit.
I don't have difficulty in seeing the centripetal force in the case of an orbiting satellite that's why I said Vs a wagon wheel. Explain to me instead why the spokes of the wheel are in tension and not compression.
The (elements of the)rim wants to go in a straight line.(N's 1st law)
The spokes pull the rim towards the centre.(i.e., apply centripetal force)
If they are in compression, then there will be forces pushing IN at both ends of it. This makes no sense, and such a force doesn't exist.
What exists is the spokes pulling in the rim. Do a free body diagram of the RIM, not the spokes. The element on the rim is being pulled in, and this force is provided by the spokes.
Still, why are we talking about the spokes and rim? The simplest case that can be illustrated clearer is a body in a circular motion around a central force, be it gravity, magnetic field, a string, etc. I can show you a CONSISTENT mathematical description of the motion of this object that causes it to move in a circular motion. Period!
You, on the other hand, can't say the same thing with your outward force. And for that, I will criticize you for it because after all this, you somehow have neglected completely the mathematical aspect of this situation. If you feel THAT strongly about this, then you need to come up with an mathematical description of the equation of motion. Go ahead and apply either Newton's laws, or Lagrangian dynamics, and show me that with an outward force, you are able to arrive at such a circular motion (or a conic section in general).
The fact that you are somehow unperturbed that your idea has no mathematical support makes this whole thing rather hollow.
Zz.
Do you agree/understand that all forces come in pairs? Try this: hold up a string in front of you and pull it into tension with both hands. Both are pulling, but in opposite directions: Do you recognize that one hand is pulling to the left and the other is pulling to the right?
I don't have difficulty in seeing the centripetal force in the case of an orbiting satellite...
Earth's gravity, pulling on the satellite, right?
Now consider the same scenario with a YoYo on a string. You are pulling on the string with your finger, to keep it moving in a circular path, right?
d4rr3n:
Sadly many things are not intuitive and cannot be understood intuitively.
The physics in this case is sound and the mathematics well proven so there is no deception.
The problem is demonstrating this requires understanding of the mathematics. For some people, this going to be utterly uninteresting and they simply aren't going to do it. However, it is the only way to truly understand what is happening here.
If you are not prepared to get in the mathematical ground work (I know, maths can be boring), and perhaps look at drawing the diagrams ZapperZ is suggesting, you may not be able to understand this, but you do have to accept it no matter how much you hate it, since it's not wrong. (If it is, all of modern engineered devices that spin in a circle are actually magickal).
EDIT: I am not a good educator so perhaps someone here can provide a link to a simple graphical tutorial that shows the forces acting? Otherwise, this will be hard to demonstrate. "Draw the free body diagram" is a correct statement but unhelpful if the OP is untrained in this.
Think about it this way: if there were no inward force, there would be no no circular motion.
If we observe an object moving in circles, something makes it going in circles. Without this "something" the object would move straight ahead. That's the Newton's first law. This "something" is an inward force. What is its origin, how it is applied - that's another thing. But just by seeing how the object behaves, we know that the force must be there.
That is correct
I don't think so, there is a torque at the center of the wheel causing rotation, the spokes resist the outward force caused by the rotation of the wheel. If the spokes were pulling the rim of the wheel inward the diameter of the wheel would reduce slightly, this absolutely does not happen. The wheel diameter in fact increases its diameter slightly as you would see if it were a spinning disc made completely of rubber.
d4rr3n said:
I don't think so, there is a torque at the center of the wheel causing rotation.
No torque if you're rotating at a constant angular velocity.
The spokes are fighting the outwards-stretching tendency of the rim, preventing the rim from stretching even further.
I think you'll be continue to be confused about this until you follow the advice given by ZapperZ and others... Start with Newton's ##F=ma##, work out what the acceleration of a point on the rim is (using coordinates in which the rim is rotating and the floor under your feet is at rest!), then see what forces in which direction are required to provide the observed acceleration.
Yes I do recognize that and that is part of the problem because physicists only talk about an inward force and a tangential force they don't talk about the outward force which is what I find confusing. If you look at the tank of water there is no inwards force on the water, if there was it would accumulate in the center of the tank but the opposite occurs. At most you can only talk about the "reactive" inward force of the tank walls resisting the outward force of the water.
The yoyo is actually climbing/descending a plain, ie it is the string applying torque on the center of the yoyo that makes it spin
