Centripetal generated by rotation of the Earth
An object weighing 100N at the South Pole weighs approximately 99.7N at the equator due to the centripetal force generated by Earth's rotation. The centripetal force, calculated as 0.3N, acts upward, countering the gravitational force. This results in a net weight reduction when measured on scales. The discussion highlights confusion regarding the direction of force vectors, particularly the distinction between gravitational force and centripetal force. Understanding these forces is crucial for accurately interpreting weight changes due to Earth's rotation.
dan667
An object weighs 100N at the South Pole. How much does it weigh at the equator?
Given: Earth's rotational spin speed 465m/s
Diameter of the Earth is 1.274 x 10^7 m
Fc = m x v^2 / r
Well I have this general understanding that the object should weigh less since it's experience uniform circular motion, and that it "wants" to fly off tangentially (Newton's first law) but is constrained by the force of friction, right? It seems I have calculated the answer of the centripetal force to be 0.3 N, but what I don't understand is that why I subtract it from 100N. The confusion lies in where the normal force and centripetal force vectors are located. It would be greatly appreciated if anyone could give a lucid answer to this question. The answer by the way, is 99.7N
The object weighs 100N so there is a force of 100N due to gravity pulling it down
At the equator there is a 0.3N force pushing it up, so if you put it on a pair of scales there would be 100N down and 0.3N up so the scales would read 99.7N
Yes, but how do you get 0.3 N pushing up? The centripetal force towards the center of Earth is 0.3 N, so the normal force is also 0.3 N. If the object is at the south pole. The only two forces would be Fg pulling it towards the center of the Earth and Fn, pushing the object upwards. But now we introduce two more forces and if you were to draw (or describe) how these force vectors are used on a FBD, what would it look like?
No - the centrepetal force is outwards.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
