How Does Water Vapor Dissociation Affect Internal Energy in a Closed System?
The discussion focuses on the thermodynamic implications of water vapor dissociation in a closed system, where a 10% temperature decrease and a 20% volume decrease were observed. Participants analyzed the relationship between internal energy, pressure, and volume changes, applying the first law of thermodynamics: ΔU = ΔQ - PΔV. The consensus is that the dissociation of water vapor leads to an increase in the number of moles, but the internal energy decreases due to the energy required for dissociation, resulting in a net reduction in volume.
  • Understanding of the first law of thermodynamics
  • Knowledge of ideal gas laws and their applications
  • Familiarity with molar heat capacities of water, hydrogen, and oxygen
  • Concept of internal energy and its dependence on temperature
  • Study the first law of thermodynamics in detail, focusing on energy transfer
  • Learn about the specific heat capacity of water vapor and its temperature dependence
  • Investigate the behavior of real gases versus ideal gases in thermodynamic processes
  • Explore the enthalpy of dissociation of water and its implications in closed systems
Students and professionals in thermodynamics, chemical engineering, and physical chemistry, particularly those interested in gas behavior and energy transformations in closed systems.
funoras
In a closed vessel there was some water vapor. After the water vapor dissociated, the temperature decreased by 10%, and the volume by 20%. Find the change in internal energy.
(U{initial}-U{final})/U{initial}
Let's state, that not all of water vapor dissociated. Let's say that in the beginning there was n moles of H_2O , and x moles of it dissociated.
Since xH_2O -> xH_2 + 0,5xO_2 , then we get x+0,5x moles in total of hydrogen and oxygen combined.The total moles of gas molecules after the dissociation would be (n-x) + (x+0,5x)=n+0,5x
Then i can write the ideal gas law before and after the dissociation.
pV=nRT_1
0.8pV=0,9(n+0,5x)RT_1
to continue, i have to find x in terms of n , but after solving the above, i get that x is a negative number. Please help !
Are you sure there is a decrease and not an increase in the volume? Are we to assume constant pressure?
AM
Thanks for your feedback.
Yes, the volume did in fact decrease. Maybe you're right , the pressure isn't constant, i can't find another explanation. But in that case there isn't enough data to solve this problem.
If i assume that all the water vapor dissociated, then why is the volume change given ? Since the internal energy only depends on the temperature.
It seems to me that the change in volume is not relevant, nor is the change in pressure.
From the temperatures and the molar heat capacities of water, hydrogen and air, you can find the relative change in internal energy.
I think you have to assume that all the vapour dissociates. If there is no heat exchange with the surroundings and if the pressure is constant, you can apply the first law:
ΔQ = ΔU + PΔV
where ΔQ is the enthalpy of dissociation of water. So ΔU = ΔQ - PΔV. Does that help?
AM
ΔQ = ΔU + PΔV
AM
Suppose we have n moles of H2O(g), then we would get a total of (3/2)n moles of H2 and O2 combined.
With the ideal gas law we would get:
{nRT_1 \over V_1} = P_1
and so:
P_2 = {3 \over 2} {n R T_2 \over V_2} = {3 \over 2} {n R \cdot 0.9 \ T_1 \over 0.8 \ V_1} = {27 \over 16} P_1
Doesn't that make it seem unlikely that the pressure would remain constant?
and so:
If the system is closed - insulated from the surroundings, the energy required for dissociation must come from the internal energy. Although the number of moles increases, I expect from the question (I haven't worked it out) that the decrease in internal energy results in a net reduction in volume. The whole process takes place at constant temperture.
AM
AM
Can't the problem be resolved without taking insulation or dissociation energy into account?
The state before and the state after seem to be uniquely defined and independent of the process path.
I meant to say constant pressure. Sorry for any confusion.
The problem is that water vapour cannot be treated as an ideal gas.
To determine its internal energy, you would have to know its specific heat capacity at constant volume. Since Cv is a function of temperature for water vapour, how do you determine its Cv without knowing its temperature?
AM
