Change in internal thermal energy.
3 replies · 3K views
bbhill
Q: 20 J of heat energy is added to an ideal gas while -40J of work is done BY the same gas. The total change in internal thermal energy of the system is what?
Equations I used: [tex]\Delta[/tex]Eth = Heat + Work
[tex]\Delta[/tex]Eth = Heat - Ws
This was a problem on a recent physics test I took and I said the answer was 60J. However, my instructor insists that the correct answer is -20J. He says that -40J of work is energy leaving the gas regardless of whether the gas is doing the work or the environment is doing the work. I don't see how this is possible. My reasoning is that (-40J) of work is done by the gas = 40J of work done ON the gas. Thus, [tex]\Delta[/tex]Eth= 20 J + 40J.
Can anyone enlighten me on why this is?
Thanks a lot!
I'm on your side. Essentially, the question contains a double negative (a negative amount of exiting energy) which your instructor is interpreting as a negative amount and you are interpreting as a positive amount.
Or look at it this way: most people would take the opposite statement, "40J of work is done by a gas," to mean that 40J of energy left the system. Your instructor is claiming, then, that replacing "40J" with "-40J" in the above sentence makes no difference, which is illogical.
You are right. The convention is to write the first law as:
dU = dQ - dW; where dQ is the heat flow INTO the gas and dW is the work done by the gas.
If you are using that convention, a negative work term means that positive work is being done ON the gas so it increases internal energy.
As Mapes noted, if the question had stated that +40J of work is done by the gas, then the change in internal energy would be dQ - dW = 20 - 40 = -20J. So it cannot be the same result if -40J is done by the gas.
Your teacher may be confusing Q with work. Work is not something that "flows" into or out of the gas. That is the case with Q (at least the model on which thermodynamics is based) but not W. Work is only done ON or BY the gas.
AM
Yeah, these are the same things I told my professor, but he stood firm on his answer. I guess I'll let it slide for now and if my grade is affected at the end of the semester I'll look back into it.
Thanks
