Change in mechanical energy of a bullet
The discussion focuses on calculating the change in mechanical energy of a bullet that stops after hitting a wall. The bullet, weighing 30g and traveling at 500m/s, experiences a change in mechanical energy primarily due to its initial kinetic energy, as potential energy remains constant when neglecting vertical displacement. The final kinetic energy is zero since the bullet comes to a stop. Participants agree that the change in mechanical energy equals the initial kinetic energy minus the final kinetic energy. The analysis suggests that the problem simplifies to considering only kinetic energy, given the horizontal motion of the bullet.
Cillie
A 30g bullet is moving at a horizontal velocity of 500m/s come to a stop 12 cm within a solid wall. What is the change in mechanical energy of the bullet?
Mechanical energy = 1/2mv^2+mgh
The question is for 6 marks, If I had to answer it, I would say the change in mechanical energy would equal the initial kinetic and potential energy of the bullet since unless I am missing something then the bullet has no energy left inside the wall, but I am not sure, so can anyone help me or make suggestions?
Potential energy in above problem is essentially gravitational energy..(you can neglect other forms they don't play much of a role here)..and anyway there is NO CHANGE in gravitational energy if the bullet went horizantally through, right?? as h is same for both initial and final situation. So basically the change in mech energy is change in kinetic energy.
Which us initial K.E. - final K.E.
final K.E. = 0 as velocity is 0.
Thanks a lot for your response.
With the information they gave us your answer is probably the one the wanted, since they didn't give the initial distance between the block and the bullet. But otherwise there would have to be a change in potential energy as the bullet would have a downwards acceleration due to gravity thus a downwards velocity and would not hit the block as the same hight it was fired at.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
