Change of variables in differential equation
The discussion centers on transforming the differential equation \((xy+z)\frac{\partial z}{\partial x}+(1-y^2)\frac{\partial z}{\partial y}=x+yz\) using the variable change \((u,v,w(u,v))=(yz-x,xz-y,xy-z)\). The solution involves applying the chain rule and product rule to derive expressions for \(\frac{\partial w}{\partial x}\) and \(\frac{\partial w}{\partial y}\). The critical point of contention is whether the condition \([y\frac{\partial w}{\partial u}+x\frac{\partial w}{\partial v}+1]=0\) holds, which leads to two cases: either \(\frac{\partial w}{\partial v}=0\) or \(1-x^2-y^2-z^2-2xyz=0\). The reference to B.P. Demidowich indicates that proving \((1-x^2-y^2-z^2-2xyz)\neq 0\) is essential for the solution.
  • Understanding of differential equations, specifically first-order partial differential equations.
  • Proficiency in applying the chain rule and product rule in calculus.
  • Familiarity with variable transformations in differential equations.
  • Knowledge of the implications of conditions in differential equations.
  • Study the application of the chain rule in multiple dimensions, focusing on partial derivatives.
  • Explore variable transformations in differential equations, particularly in the context of non-linear equations.
  • Investigate the implications of conditions like \((1-x^2-y^2-z^2-2xyz)=0\) in the context of solution existence.
  • Review B.P. Demidowich's methods for solving differential equations for additional insights.
Mathematicians, students studying differential equations, and researchers interested in advanced calculus and variable transformations will benefit from this discussion.
michalpp
I have to transform the following equation using variables [tex](u,v,w(u,v))=(yz-x,xz-y, xy-z)[/tex]:
[tex](xy+z)\frac{\partial z}{\partial x}+(1-y^2)\frac{\partial z}{\partial y}=x+yz.[/tex]
chain rule: [tex] \frac{dw}{dx} = \frac{\partial w}{\partial u} \frac{\partial du}{\partial dx} + \frac{\partial w}{\partial v} \frac{\partial dv}{\partial dx}[/tex]
Using the chain rule and the product rule:
[tex]\frac{\partial w}{\partial x}=\frac{\partial z}{\partial x}(y\frac{\partial w}{\partial u}+x\frac{\partial w}{\partial v})-\frac{\partial w}{\partial u}+z\frac{\partial w}{\partial v}[/tex]
and a similar expression for [tex]\frac{\partial w}{\partial y}[/tex].
On the other hand
[tex]w=xy-z[/tex], so
[tex]\frac{\partial w}{\partial x}=y-\frac{\partial z}{\partial x}[/tex]
(and similar for [tex]\frac{\partial w}{\partial y}[/tex]), so
[tex]\frac{\partial z}{\partial x}(y\frac{\partial w}{\partial u}+x\frac{\partial w}{\partial v})-\frac{\partial w}{\partial u}+z\frac{\partial w}{\partial v}=y-\frac{\partial z}{\partial x}[/tex] and therefore:
[tex]\frac{\partial z}{\partial x}[y\frac{\partial w}{\partial u}+x\frac{\partial w}{\partial v}+1]=y+\frac{\partial w}{\partial u}-z\frac{\partial w}{\partial v}[/tex] and
[tex]\frac{\partial z}{\partial y}[y\frac{\partial w}{\partial u}+x\frac{\partial w}{\partial v}+1]=x+\frac{\partial w}{\partial v}-z\frac{\partial w}{\partial u}.[/tex]
After multiplying the given equation by
[tex][y\frac{\partial w}{\partial u}+x\frac{\partial w}{\partial v}+1][/tex]
and writing
[tex]\frac{\partial z}{\partial x}[y\frac{\partial w}{\partial u}+x\frac{\partial w}{\partial v}+1][/tex] as [tex]y+\frac{\partial w}{\partial u}-z\frac{\partial w}{\partial v}[/tex] I get
[tex]\frac{\partial w}{\partial v}(1-x^2-y^2-z^2-2xyz)=0.[/tex]
If
[tex][y\frac{\partial w}{\partial u}+x\frac{\partial w}{\partial v}+1]\neq 0[/tex]
this equation is equivalent to the given one. But what if [tex][y\frac{\partial w}{\partial u}+x\frac{\partial w}{\partial v}+1]=0[/tex]?.
I'm kind of stuck at this point, cause in the first case
[tex]\frac{\partial w}{\partial v}=0[/tex] or [tex](1-x^2-y^2-z^2-2xyz)=0[/tex].
I was thinking of a way to change [tex](x,y,z)[/tex] to [tex](u,v,w)[/tex] in the last equation, but without success. I also have no idea what to do in the second case. So what should I do now? Is this a correct method to solve a problem like this?
I've found the answer to this problem in a book by B.P. Demidowich - it says
[tex] \frac{\partial w}{\partial v}=0[/tex]
So this means that I need a proof that
[tex] (1-x^2-y^2-z^2-2xyz)\neq 0[/tex], or do I still miss something?
[tex] (1-x^2-y^2-z^2-2xyz)=(xy+z)z+(1-y^2)(-1)+x(x+yz)[/tex]
looks similar to
[tex] (xy+z)\frac{\partial z}{\partial x}+(1-y^2)\frac{\partial z}{\partial y}=x+yz.[/tex] but I don't have other ideas.
  • · Replies 18 ·
