Changing Order of Integration in Triple Integrals
The discussion focuses on changing the order of integration in a triple integral from dx dy dz to dz dy dx. The original integral describes the first octant of a sphere with radius 3, where z ranges from 0 to 3, y from 0 to √(9-z²), and x from 0 to √(9-y²-z²). When changing the order, the limits for z become 0 to √(9-x²-y²), while x retains fixed limits of 0 to 3. The participants emphasize that due to the symmetry of the sphere, the limits of integration remain consistent across different orders. The final expression for the integral in the new order is confirmed as correct.
boneill3
Given
\int{0}{3} \int{0}{sqrt{(9-z^2)}} \int{0}{sqrt{(9-y^2-z^2)}} dx dy dz
express the integral as an equivalent in dz dy dx
From the origial limits z goes from 0 to when x^2 + y^2 <= 9
For dz I have
\int{0}{ sqrt(-x^2-y^2+9)} dz
Is this right so far?
boneill3 said:
Given
For dz I have
In the original integral z goes from 0 to 3, for each z, y from 0 to \sqrt{9-z^2}, and, for each y and z, x goes from 0 to \sqrt{9- x^2- y^2}.
That last is, of course, the upper hemisphere of x^2+ y^2+ z^2= 9 while the y integral is over the upper semi-circle of y^2+ z^2= 9. Finally the z integral over a radius of that circle and sphere. This is the first "octant" of the sphere of radius 3. Yes, If you change the order of integration so you are integrating with respect to z first, z goes from 0 to \sqrt{9- x^2+ y^2}.
Because of symmetry, this is a very easy problem!
For dx
Do you leave the limit as \int{0}{sqrt{(9-y^2-z^2)}}dx or do you change it to
\int{0}{3} dx
\int{0}{3} \int{0}{sqrt{(9-z^2)}} \int{0}{ sqrt(9-x^2-y^2)} dz dy dx
regards
boneill3 said:
For dx
\int{0}{3} dx
regards
Since the x integral is the "outer" integral here, its limits of integration must be numbers, not functions of y and z! Yes, the limits are 0 and 3.
My point about the symmetry is that since this is an octant of a sphere, all choices of order are the same: except for "permuting" x, y, and z, those are exactly the limits of integration you had originally.
Thanks
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
