Measuring voltage from a high impedance source with a standard voltmeter (10 mega ohms) can yield inaccurate readings due to loading effects. Simply replacing the internal resistor with a higher value (100 mega ohms) is not feasible, as the meter's circuitry is designed for a specific impedance and altering it could cause inaccuracies. Instead, using a 100 mega ohm resistor in series with the voltmeter can help, but this may reduce accuracy due to voltage division. For precise measurements, a high impedance booster amplifier or specialized high impedance voltmeter is recommended, although these can be expensive. Understanding the source impedance and using proper techniques can improve measurement accuracy without needing to modify the voltmeter.
