Undergrad Characteristic X Rays: Understanding Atom Reversion
Characteristic X-rays are produced when an accelerated electron knocks out a K-electron from an atom, leading to an L-electron filling the vacancy. This process can create a series of vacancies as higher-level electrons drop to fill lower energy states. However, these transitions do not continue indefinitely; eventually, the atom will regain neutrality by acquiring an electron from an external source. This external source can be a physical connection to ground, the device chassis, or even the surrounding air. Understanding this process clarifies how atoms return to their normal state after ionization events.
Viona
I was reading about characteristic x rays. I have a question I did not find an answer for it in the book (Concepts of Modern Physics-Sixth Edition-Arthur Beiser) or in the internet search. My question is:
How do the atom in the target (in the x ray production experiment) go to the normal state if the accelerated electron (from the cathode) knocks a k-electron out the atom and L-electron jumps to fill the vacancy there will be another vacancy, Do these transitions from higher levels continue in series till finally the atom ionized?
I assume you mean neutralized, not ionized. It will be neutralized by taking an electron at some point. Where that electron comes from could be a physical connection to ground, to the chassis of the device, or even the air if given enough time.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 17 ·
  • · Replies 28 ·
