Charge accelerates at bends of the wire?
  • Thread starter Thread starter gmish27
    Charge Wire
Charge accelerates at bends in a wire due to the need to maintain a constant electric field and current direction, as explained by Gauss's law. When a wire bends, the electric field must adjust to ensure that the current remains consistent, resulting in a downward flux at the bend. This creates surface charges, likely positive, on the outer corner of the bend to balance the electric field. The presence of these surface charges facilitates the acceleration of charge carriers in the wire. Thus, the behavior of charge near bends is crucial for understanding current flow in conductive materials.
gmish27
charge accelerates at bends of the wire?
hello! can anyone make me understand why and how charge gets accelerated near the bends of wire?
It follows from Gauss's law.
Say you have a long, horizontal wire of uniform width, with current flowing from left to right. Draw a box in the wire. The flux through the box is zero, since the electric field is constant in the wire (which is why there is a constant current). Now suppose there is a bend in the wire, say 90 degrees downwards. Draw a Gaussian pillbox at the outside corner of the bend that goes through the upper surface of the horizontal wire. Now in order to maintain a constant current, the electric field must have the same magnitude everywhere in the wire, and must always point in the same direction as the wire. So through the pillbox, there is a flux downwards since current is going down through the bend. There is no flux through the left or right sides, since the pillbox has small walls in those directions. So the only way that the total flux is zero is if electric field comes through the top of the pillbox. But where would this electric field come from? So one is forced to conclude that there is charge on the top surface near the bend, most likely a positive charge.
So basically surface charges near the bends of wire accelerate the charge.
You can plug in numbers yourself. You'll find that for each amp of current that flows through a copper wire, there is about one electron's worth of charge at the bend, so it doesn't much to cause the current to bend.
thnx for the clarification
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
