Charge Density and Diract Delta Functions
The discussion focuses on deriving expressions for volume charge density using Dirac delta functions. For the first problem, the proposed solution is p(r) = [δ(r - Di)(-3q) + δ(r + Di)(q)], which correctly represents the charges at specified positions. In the second problem, the challenge lies in expressing the linear charge density in cylindrical coordinates, where the initial attempt resulted in incorrect units. A suggestion is made to use δ3(r) for point charges and δ2(r) for line charges to ensure proper dimensionality. Understanding the units of Dirac delta functions is crucial for accurate formulations in both Cartesian and cylindrical coordinates.
definerandom
a) A charge q1 = q is at r'1 = -Di, and a charge q2 = -3q is at r'2 = Di. Find an expression for the volume charge density p(r).
b) An infinitely long wire along the z-axis has a uniform linear charge density \lambda. Find an expression for the volume charge density p(r) in cylindrical coordinates.
\int\delta(x) dx = 1
a) I'm not sure how to format my solution for the question, but I came up with this:
p(r) = [\delta(r - Di)(-3q) + \delta(r + Di)(q)]
b) I can't figure out how to do this with cylindrical coordinates. With Cartesian coordinates I came up with this:
p(x,y,z) = \delta(x)\delta(y)\lambda
When I try with cylindrical coordinates, I realize that r must equal zero, so I know \delta(r) would be part of the expression; however, \theta can be any value, as can z. That results in this:
p(r,\theta,z) = \delta(r)\lambda
which has incorrect units for volume charge density.
Any help on this question is greatly appreciated!
Hello definerandom,
Welcome to Physics Forums!
If you want to get the units correct, perhaps consider using δ3(r) = δ(x)δ(y)δ(z) = δ(r)δ()δ(rsinθΦ) for points, and δ2(r) = δ(x)δ(y) = δ(r)δ() for lines (where the z component is not included in r in the second case).
[Edit: Modified the cylindrical and polar representations. Anyway, the point being is that you can square or cube the Dirac delta function as appropriate, noting that each Dirac delta function has units of 1/length (such as 1/meters, for example.)
[Another edit: So in other words, when dealing with points, you should end up with δ3(), which has units of length-3. When working with lines, δ2() which has units of length-2.]
  • · Replies 36 ·
  • · Replies 16 ·
