Charge of a sphere, thin circular hoop
Oloria
What minimal charge should have a sphere of radius R to surpass a thin circular hoop of radius r that is uniformly distributed with the charge Q and made from resilient elastic. The elastic modulus (of resilience) is \Psi. R>r
Coulomb's law.
IMO the electric force is F = \frac{k_e Q q}{R^2}. What's then? I haven't got the slightest idea. Help me, please.
Hi Oloria! :smile:
(have a psi: ψ :wink:)
The idea is to expand the hoop …
so what will be the "horizontal" radial force on the hoop if the charge on the sphere is -P ?
Hi tiny-tim :smile:
I think the electrici force got to be bacbalanced by a force connected with resilience. I think F~ψ but I don't know how to write it down properly.
I don't understand why you used "-P" and I don't know what answer you expect (I have already mentioned Coulomb's law).
Hi Oloria! :smile:
The sphere must have negative charge, so that it can repel the hoop, and make it bigger. :wink:
Forget the elastic force for the time being …
just calculate the "horizontal" radial electric force from the sphere on the hoop …
what do you get? :smile:
Repel? I thought there should be Q and -q so they attract each other. I don't understand :(
F = \frac{k_e Qq}{R^2} I guess the distance between midpoints of these two objects is R. q is the charge on the sphere.
oops! :redface: i misread the question, yes it'll be Q and q, so the sphere makes the hoop larger :smile:
Q and -q, am I right?
And I don't know what to do next. Can you help me, please?
No, Q and q: the sphere must repel the hoop, so that the hoop is the same radius (R) as the sphere.
What is the electric force between a sphere of charge q and a hoop of charge Q that just fits onto the equator of the sphere?
F = \frac{k_e Qq}{R^2}?
I thought the sphere will repel a hoop so it will be impossible to start surpassing (being so close of two objects). (When the sphere is in the hoop they have to repel each other so the hoop will be larger).
It depends how fast you push the sphere, or whether the hoop is fixed somehow.
Anyway, now match the electric force with the elastic force. :smile:
But I don't know how to write down the elastic forse. Could you help me?
Consider an extremely small arc of angle 2θ radians …
if T is the tension in the hoop, and if the radial force is F/2π per radian, find the equation relating T and F, and then let θ tend to zero. :wink:
(alternatively, you could use the work-energy theorem)
