Charge q located a large distance from a neutral atom
The discussion focuses on calculating the force of attraction between a point charge q and a neutral atom with polarisability α at a large distance r. The derived formula for the attractive force is F = -2αq²/(4πε₀)²r⁵, indicating that the force diminishes with the fifth power of distance. The conversation clarifies that the approximation of large distance is essential, as it ensures that r is significantly greater than the effective distance of the dipole moment. The relationship between monopoles and dipoles is also explored, emphasizing the varying force dependencies based on their configurations.
  • Understanding of electrostatics and Coulomb's law
  • Familiarity with dipole moments and polarisability
  • Knowledge of vector calculus in physics
  • Basic grasp of force equations in electromagnetism
  • Study the derivation of the electric field due to dipoles in detail
  • Learn about the physical implications of polarisability in different materials
  • Explore the concept of induced dipoles and their effects on force calculations
  • Investigate the behavior of forces between multiple dipoles and induced dipoles
Students and professionals in physics, particularly those studying electromagnetism, electrostatics, and molecular interactions. This discussion is beneficial for anyone looking to deepen their understanding of forces between charges and dipoles.
gfxroad
A point charge q is situated a large distance r from a neutral atom of polarisability α. Find the force of attraction between them.
\vec{E}_{mono}(r)=\frac{q}{4\pi\epsilon_0r^2}\hat{r}
\vec{E}_{dip}(r,\theta)=\frac{p}{4\pi\epsilon_0r^3}(2\cos\theta\hat{r}+ \sin\theta\hat{\theta})
\vec{p}=\alpha\vec{E}
\vec{F}=q\vec{E}
F=\frac{-2\alpha q^{2}}{\left(4\pi\epsilon_{0}\right)^{2}r^{5}} attractive force
My questions are that I wonder about the \frac{1}{r^{5}}, is't acceptable? and what is physically meaning of (large distance r from a neutral atom)
I agree with that answer.
To get it, you had to make an approximation with regard to distances, right? That is the reason you are told r is large. I.e. it is large compared with the effective distance (whatever that means) of the dipole moment.
  • Force between two monopoles ~ 1/r2
  • Force between a monopole and a dipole ~ 1/r3
  • Force between a monopole and an induced dipole (the one you calculated) ~ 1/r5
  • Force between two dipoles ~ 1/r4
  • Force between dipole and induced dipole ~ 1/r7
  • Force between two induced dipoles (each one induces the other) ~ I'm leaving that as an exercise. Can you figure it out?
I agree with this also. Your E_r expression implicitly assumes r >> distance between dipole charges.
I'm attaching a good set of notes for this topic.
  • · Replies 17 ·
  • · Replies 18 ·
