Can a centrifuge be used to induce fusion in ions?
In summary, the conversation revolves around the possibility of using a centrifuge to accelerate ions and coerce them into fusing into heavier elements. This idea is met with varying degrees of interest and skepticism, with some pointing out the challenges of achieving fusion with this method and others suggesting alternative approaches such as heating the gas with lasers. The primary obstacle discussed is the difficulty of containing and sustaining the fusion reaction, with the participants also touching on the role of quantum tunneling and the use of electromagnetic fields.
schwarzchildradius
Can we consruct a centrifuge to accelerate ions and coerce them to fuse into heavier elements? It would have to be a sweeping electric field, because any moving parts would disintegrate from the great velocity they'd invariably have to have. Think fusion could be achieved this way?
Science news on Phys.org
Intriguing idea. It would be one hell of an engineering challenge and it would be interesting to see if it took us a lot more energy to just get that electric field in the first place than to run the fusion reaction.
Could be difficult. I suspect the energy required to do it that way would be huge. Nice idea though.
spooky interesting...
Isn't this essentially a particle accelerator as currently exists as places lile CERN and Fermi Labs? Ions are routinly accelerated to sigificant fractions of c and collided with similar beams rotatinging the opposite direction to create hi energy collisions between fundamental particles.
Great Idea, but hardly original. :wink:
Yes, except that I want to force the ions into the same place on the ring, instead of spread out evenly along the ring, the idea being that one could build up a significant number of ions together.
I don't think great velocity need be primary so much as very precise velocity, I mean it may not be so much the speed of the collision as the exact trajectory like trying to land squarely on the top of a pyramid that is repulsive to anything moving toward it, unless it follows a perfectly straight flight path it will bounce off and slide down the side or in less it is moving at tremendous speeds in which the repulsive factor hasn't enough time to deflect the path, but if it lands exactly fusion might result. That's my crackpot analogy anyway, but doens't fusion always take energy and fission create it?
Greetings !
There are many ideas that deal with accelerating
hydrogen/its isotopes and squezing them together
(a Tokomak essentially) and also ideas of smashing
them together. But they are not suffciently effective.
The distance required for fusing hydrogen is
about 10^-15 m and that's very difficult to acvhieve.
Live long and prosper.
Sheesh, an atom is small enough that's about 100k times smaller.
Maybe I should have said like trying to launch from space and land your skateboard on the tip of a repulsive pyramid.
all right then, I have a question for you drag: why can't we accumulate enough ions in one place in a Tokamak to start sustainable reaction (or can we) ? The idea though is that instead of heating the fuel, you just accelerate it enough that the force from circular motion, (by default acceleration,) is greater than the coulomb repulive force etc.
Greetings !
Pure numbers. I think your mathematical skills
by far exceed mine schwarz so I'm sure you
can easily do this and see the problem.
(Basicly, if we need to overcome say a few KeV
than we're talking about velocities equivalent
to about 10^6 m/sec which is pretty high for
protons and hydrogen isotopes.)
Circuilar accelerators are used because you can
accelerate the particles and then maintain the
velocity with relativly little more energy input
over a fairly long time period, thus increasing
the likeliness of the reaction and the total
energy output to input ratio.
There are basicly 3 ways (as you may know) to
contain a sustained fusion reaction:
1. Gravitational.
2. Electromagnetic.
3. Enertial.
Of course, in this case we are not talking about
a direct self-sustaining reaction. However, the
same methods are also required to enitiate it.
BTW, an interesting thing that Warren(chroot), I
believe, said in a different thread - quantum
tunneling plays a significant part in a star's
fusion process. Thus, had there been no quantum
tunnelling the star would have to be more massive
to enitiate and contain the reaction. (I have not
confirmed this personally and he did not answer
my question back then so I can't say how much
is "significant".)
So, theoreticly, if we could increase the chances
of the relevant particles to tunnel and fuse
we could increase the output this way too. But,
if I'm not mistaken there is currently no way to
do this and QM does not allow this.
cool. that's interesting.
I think it's cheaper just heating up the gas with lasers. The ol'fashion way :)
Either way you need the very strong EM fields to
maintain the plasma and thus sustain the reaction.
Don't forget that in a circular accelerator, synchrotron radiation tends lessen the energy of a particle beam. That's why circular accelerators (like the tevatron) have such a wide diameter. But maybe you could use this radiation to exite incoming ions in a centrifuge chamber? Kind of like pre-heating if that's possible. In either case drag is right; it's pure numbers. More energy in than out I assume.
I think AH meant heating without the use
of an accelerator but by simply containing the
plasma and using laser beams. Synchrotron or
Bremstahlung radiation energy losses are probably
not very significant in such a case.
Looks like a misunderstanding. I wasn't replying to AH's post although it does look that way. And you're right. I noticed that synchrotron raditation output in Watts as pretty small. My bad.
1. What is "cheating nature" in the context of fusion?
Cheating nature refers to using various methods and techniques to artificially create a stable fusion reaction that can produce energy, instead of relying on natural occurrences such as those seen in stars.
2. Why is it difficult to achieve fusion without "cheating nature"?
Fusion is a highly complex process that requires high temperatures and pressures to overcome the repulsion between positively charged nuclei. Without "cheating nature" and artificially creating these conditions, fusion reactions would be nearly impossible to achieve in a controlled and sustained manner.
3. What are some examples of "cheating nature" in fusion research?
Examples of "cheating nature" in fusion research include using magnetic confinement, inertial confinement, and laser heating techniques to create the necessary conditions for fusion reactions to occur. These methods mimic the extreme conditions found in stars and allow for controlled fusion reactions to take place.
4. What are the potential benefits of successfully "cheating nature" out of fusion?
If scientists are able to successfully create a sustainable fusion reaction, it could provide a nearly limitless source of clean energy that produces very little waste. This could greatly reduce our reliance on fossil fuels and help mitigate the effects of climate change.
5. What are the challenges and limitations of "cheating nature" in fusion research?
There are still many challenges and limitations in achieving sustainable fusion reactions, despite the advancements made in "cheating nature" techniques. Some of these challenges include finding suitable materials to withstand the extreme conditions, controlling and stabilizing the reactions, and finding ways to scale up the process for practical energy production.
  • High Energy, Nuclear, Particle Physics
  • Materials and Chemical Engineering
  • Nuclear Engineering
  • Classical Physics
