Troubleshooting Fortran Errors: How to Fix Code Compilation Issues
In summary: I know that g95, for example, if you have an environment variable declared appropriately, it will tell you about it, etc.Yes, I have an environment variable declared appropriately. I set it to "g95 -error-reporting=warnings".Wherever you are doing division, put in a guard statement to prevent division by zero.For example, if I'm going to divide by radius (an integer value), I can do this:IF radius .neq. 0 THENresult = numerator / radiusELSEWRITE *, "Error - Division by zero."ENDIFIf the denominator is a floating point value, the above won't
alcantara_20
Dear all,
I'm write code in Fortran language when compile my program I got error message :
forrtl: severe (71): integer divide by zero
Image PC Routine Line Source
f0511 00000000007536A5 Unknown Unknown Unknown
f0511 00000000007538C8 Unknown Unknown Unknown
f0511 000000000040347C Unknown Unknown Unknown
libc.so.6 000000338101ECDD Unknown Unknown Unknown
f0511 0000000000403379 Unknown Unknown Unknown
make: *** [all] Error 71
How I can fix this problem if the error message didn't give the line that indicates error? I don't have idea to solve this.
Technology news on Phys.org
alcantara_20 said:
Dear all,
Are you doing any division in your code? That's where I would look.
If you still can't find the problem, post your code and we'll take a look.
read the user's manual for the compiler, look for flags to enhance runtime error reporting, like debug, or not removing the symbol table or divide-by-zero...I know that g95, for example, if you have an environment variable declared appropriately, it will tell you about it, etc.
Yes I doing any division in my code. I tried to put flags in my code the error messages still same.
Code:
ELSE
ENDIF
If the denominator is a floating point value, the above won't work, but something like the following will work.
Code:
IF ABS(radius) .leq. 1E-07 THEN
ELSE
ENDIF
If radius is a number between -.0000001 and +.0000001, the division is not performed. I picked the value to test against somewhat arbitrarily - you can use a smaller value or one that is larger.
Thank Mark44 I will try your solution. :smile:
I forgot that I'm not use division. When I try put for if else end if, I still get error. This is my line code:
Factorize A
Factorize A
call cpu_time(start)
CALL dgetrf(n,n,a,lda,ipiv,info)
IF (info==0) THEN
! Compute solution
CALL dgetrs(trans,n,nrhs,a,lda,ipiv,b,ldb,info)
call cpu_time(finish)
! Print solution
! ifail: behaviour on error exit
! =0 for hard exit, =1 for quiet-soft, =-1 for noisy-soft
ifail = 0
DO I = 1,N
!print 1000, b(i,nrhs)
END DO
print*,B(5,1)
!print*,B
ELSE
WRITE (nout,*) 'The factor U is singular'
END IF
print *,'time OV=',finish - start
I already use else if for another purpose how I put another branch for condition integer divide by zero ?
Your code isn't complete enough to determine what's going wrong, but I would bet that you are not calling dgetrs subroutine correctly or that your Fortran installation is not set up correctly so that the compiler is not able to find the lapack library code.
Here's a link to some documentation for dgetrs - http://www.nag.co.uk/numeric/fl/manual/pdf/F07/f07aef.pdf.
I still figure out the error base from your suggestion Mark44
It is apparent to me that English is not your first language. What you said here means that you figured out the problem, but I suspect that is not the case.
Yes I still figured out the problem. Because I tried check again and I still got the same error massage.
When you "figure out" a problem, you are finding a solution for it.
So you are still experiencing the problem. You did NOT figure it out.
Did you try the suggestion I made in post #8?
I tried your suggestion moreover I found the new documentation for f07aef but I still can't find the solution.
I believe that the error you are seeing is due to incorrect parameters in your call to dgetrs.
Code:
What are the values of the parameters you are using when you call dgetrs?
Section 5 Parameters in the documentation in the link I sent explains each parameter.
I still can't find the solution. I post my code and tried your solution but still can't find the solution of my problem.
This the main program of my code :
READ (nin,*)
READ (nin,*) n, nrhs
lda = n
ldb = n
ALLOCATE (a(lda,n),b(ldb,nrhs),ipiv(n))
ALLOCATE (a1(lda,n),b1(ldb,nrhs))
! Read A and B from data file
! READ (nin,*) (a1(i,1:n),i=1,n)
! READ (nin,*) (b1(i,1:nrhs),i=1,n)
do i = 1,n
do j = 1,n
read (nin,*),a1(i,j)
end do
end do
do i = 1,n
read (nin,*),b1(i,nrhs)
end do
DO I = 1,N
DO J = 1,N
a(I,J) = (a1(I,J),1.1d0)
END DO
END DO
DO I = 1,N
DO J = 1, NRHS
b(I,J) = (b1(I,J),1.0d0)
END DO
END DO
! Factorize A
IF (info==0) THEN
! Compute solution
! Print solution
ifail = 0
!CALL x04caf('General',' ',n,nrhs,b,ldb,'Solution(s)',ifail)
DO I = 1,N
END DO
print*,B(5,1)
!print*,B
ELSE
END IF
DEALLOCATE (A,B,IPIV,A1,B1)
1000 FORMAT (F10.4)
SUBROUTINE GET_INPUT(N,NRHS,A,B)
INTEGER ::N, NRHS, I, J, K
DOUBLE PRECISION :: A(N,N), B(N,NRHS)
k = n*n+1
DO I = 1,N
B(I,NRHS) = 1.D0
DO J = 1,N
A(I,J) = ran(k)*(5-(-5)) -5
END DO
END DO
END SUBROUTINE
Add some tracing statements like
Code:
print *,'I am here!'
or
Code:
print *,'Data read properly'
It will help you localize the line that generates error.
Your suggestion really help me. Thank you very much
You haven't shown us the complete main program, especially where the variables are declared.
alcantara_20 said:
READ (nin,*)
lda = n
ldb = n
do i = 1,n
do j = 1,n
end do
end do
do i = 1,n
end do
DO I = 1,N
DO J = 1,N
END DO
END DO
What are you doing in the loop above? I'm pretty sure it's not allowed.
alcantara_20 said:
DO I = 1,N
DO J = 1, NRHS
END DO
END DO
Same question as above.
alcantara_20 said:
! Factorize A
IF (info==0) THEN
! Compute solution
I don't see a variable named trans anywhere in your code. That variable needs to have a value before you call this function.
! Print solution
ifail = 0
DO I = 1,N
END DO
print*,B(5,1)
!print*,B
ELSE
END IF
1000 FORMAT (F10.4)
What's the purpose of this subroutine? You don't call it anywhere in the code above.
k = n*n+1
DO I = 1,N
B(I,NRHS) = 1.D0
DO J = 1,N
END DO
END DO
END SUBROUTINE
What is Fortran?
Fortran is a high-level programming language commonly used for scientific and numerical computing. It was developed in the 1950s and has evolved over the years to remain relevant in modern computing.
What are common errors that occur during Fortran code compilation?
Some common errors during Fortran code compilation include syntax errors, undefined variables or functions, and mismatched data types.
How can I fix syntax errors in Fortran code?
To fix syntax errors, carefully review your code and check for missing or misplaced punctuation, incorrect use of keywords, and other common mistakes. You can also use a compiler or IDE with built-in syntax checking tools.
What should I do if I encounter undefined variables or functions during compilation?
If you encounter undefined variables or functions, make sure they are declared and defined correctly in your code. If they are being used from another module or program, check that they are properly imported or included.
How can I troubleshoot mismatched data types in Fortran code?
To troubleshoot mismatched data types, check that the types of variables and functions are consistent throughout your code. Use explicit type declarations and conversion functions when necessary.
