Check whether I am correct in Chain Rule
  • Thread starter Thread starter yungman
    Chain Chain rule
yungman
If ##r## is a function of ## x,y##, then
\delta r= \frac{\partial r}{\partial x}\delta x + \frac{\partial r}{\partial y}\delta y
Means
Small change of r = ##\left[\frac{\partial r}{\partial x}\right]_{y=k}## X (Small change of x) + ##\left[\frac{\partial r}{\partial y}\right]_{x=k}## X (Small change of y)
Where ##k## is a constant.
Except that your (k,k)-point in the (x,y)-plane should be replaced with the arbitrary (x_0,y_0)-points, that is the constant values of x and y need not be the same.
Likes 1 person
Thanks, I meant k is some constant, I should have specified the two need not be the same.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
