Checking if H is a subgroup of G
  • Thread starter Thread starter Samuelb88
    Subgroup
Samuelb88
Let [itex]G = GL_n(\mathbb{C})[/itex] and [itex]H = GL_n(\mathbb{R})[/itex]
Prop. A subset H of a group G is a subgroup if:
1. If [itex]a,b \in H[/itex], then [itex]ab \in H[/itex].
2. [itex]1 \in H[/itex]
3. [itex]\forall a \in H[/itex] [itex]\exists a^{-1} \in H[/itex].
My intuition says the answer is yes since the [itex]\mathbb{R} \subset \mathbb{C}[/itex], it seems reasonable to say the same about the general linear group of invertible [itex]n \times n[/itex] matrices. So if I am understanding how to check if H is a subgroup of G correctly, I need to test the three conditions above. Here goes:
1. Let [itex]a,b \in GL_n(\mathbb{R})[/itex]. Then the product of two [itex]n \times n[/itex] matrices [itex]a,b[/itex] is an [itex]n \times n[/itex] matrix [itex]ab[/itex]. Thus [itex]ab \in GL_n(\mathbb{R})[/itex].
2. The [itex]n \times n[/itex] identity matrix [itex]I \in GL_n(\mathbb{R})[/itex] since [itex]\det(I)=1[/itex] [itex]\forall n[/itex].
3. From the definition of [itex]GL_n(\mathbb{R}) = \{ n \times n \, \, \, invertible \, \, \, real \, \, \, matrices\}[/itex], it follows that [itex]\forall a \in GL_n(\mathbb{R})[/itex] [itex]\exists a^{-1} \in GL_n(\mathbb{R})[/itex].
So does this show that [itex]GL_n(\mathbb{R}) \subset GL_n(\mathbb{C})[/itex]? I'm confused since I haven't even mentioned [itex]GL_n(\mathbb{C})[/itex].
Yes, you did. You said that [itex]GL_n(\mathbb{R})\subset GL_n(\mathbb{C})[/itex]. Once you have that, you only need to look at [itex]GL_n(\mathbb{R})[/itex].
