Chemical-plant equipment costs vary to size
The discussion revolves around the cost variations of chemical-plant equipment in relation to size, specifically through the lens of an allometric equation. Participants explore the implications of this equation on cost per unit size and the specific case of a spherical storage tank, examining how size and material properties influence costs.
  • Homework-related
  • One participant states that the cost varies with size according to the allometric equation, C = aSb, where the exponent b is typically between 0 and 1, suggesting a decrease in cost per unit size with increasing size.
  • Another participant is asked to consider the volume of a sphere and how it relates to the cost of material, indicating a connection between geometric properties and cost implications.
  • A participant confirms the formula for the volume of a sphere as 4/3*pi*r^3 and seeks further guidance on how to relate this to cost.
  • There is a repeated inquiry about additional equations that could indicate cost with respect to material, reflecting a search for deeper understanding of the relationship between geometry and cost.
  • Discussion includes a suggestion to consider the volume of the shell and its density to explore cost implications further.
Participants are engaged in a collaborative exploration of the problem, with some expressing uncertainty about the specific requirements of the homework. There is no clear consensus on how to approach part b of the question, indicating that multiple interpretations or methods may exist.
Participants express uncertainty regarding the parameters affecting the constant a in the allometric equation and the specific application of geometric properties to cost calculations. The discussion does not resolve these uncertainties.
Ortanul
Chemical-plant equipment costs rarely vary in proportion to (i.e., linearly with) size. In the
simplest case, cost varies with size according to the allometric equation, C = aSb
The exponent is typically between 0 and 1. For a wide variety of equipment types, it is approximately 0.6.
  1. (a) For 0 < b < 1, show that cost per unit size decreases with increasing size, resulting in an economy of scale.
  2. (b) Consider the case of a spherical storage tank. The size is commonly measured by internal volume Vt. Show that b = 2/3. On what parameters or properties would you expect the quantity a to depend?
formulas for derivative
For part a, I calculated the derivative of C/S with respect to the size, which equals to (b-1)*a*Sb-2. As the value of b-1 is negative, the value of this derivative is always negative, and so the increase in size would result in a decrease in the cost per unit size.
I don't understand what part b is asking about though. Compared with part a, it doesn't give anything apart from telling me that the tank is spherical. I have completely no clue about how to obtain a specific value for b without any additional information.
Any help would be much appreciated!
@Ortanul, Hi
What is the volume of a sphere of radius r?
Then, what other equation of a sphere could one apply that might indicate its cost with regard to its cost of material. How would you find that?
@265bits
Thanks for your reply!
The equation for calculating the volume is 4/3*pi*r^3
While for the other equation... Could you please give me a hint?
256bits said:
@Ortanul, Hi
What is the volume of the shell. What do you get if you multiply this by the density of the shell metal?
