Is the chemical used with caution in home and lab, could it be acid?
The discussion revolves around identifying a chemical term related to safety in home and lab settings, specifically focusing on a crossword puzzle clue. The first clue hints at a metal mesh used to prevent glassware from cracking when heated, while the second clue suggests a chemical that requires careful handling. Participants consider "acid" as a potential answer, acknowledging that while acids vary in safety, the term fits the crossword criteria. There is also a suggestion that "glove" could be a suitable answer for the first clue, given its letter constraints. Overall, the conversation emphasizes the importance of safety when dealing with chemicals in various environments.
whitehorsey
1. 1. a.Metal mesh used to prevent glassware from cracking when heated with a Bunsen burner
b. A type of chemical which must be respected and handled carefully in the home and laboratory.
2.None
3. I have to figure out what the word is because its a crossword puzzle and it does provide me with any words that I can choose from, but for a. it has 5 boxes and the 1st box is g. For b. which is across it has 4 boxes and the 1st box is a. Is it acid?
Acid sounds possible, even if the description is a little bit misleading - there are many types of acids and some are quite safe.
thanx for a. about the Metal mesh used to prevent glassware from cracking when heated with a Bunsen Burner is it a glove? -- it seems to be the only answer that would fit in the 5 boxes given with G as the first letter.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
