MHB Solution: Sharing Cards - How Many are Shared Among 20+ Children?
  • Thread starter Thread starter Johnx1
    Cards Children
Twenty children share a total number of cards equally, denoted as 20x. When a new child joins, each child receives 2 fewer cards, leading to the equation 20x = 21(x - 2). Solving this equation reveals that the total number of cards shared among the children is 840. The discussion emphasizes the mathematical approach to solving the problem by setting up the correct equations. The final answer confirms the total number of cards shared.
Johnx1
20 children share some cards equally. When another child joins them, they each get 2 fewer cards. How many cards are they sharing altogether?
My answer:
children = ch
cards = cd
=> cd/ch
but when another child joins them, they get 2 fewer cards. So, ch = cds - 2.
then I did cd/20(cds - 2)
Then I got stuck there for a long time.
Mathematics news on Phys.org
Let the number of cards per child be x. Since 20 children are sharing the same number of cards there are 20x cards available. When another child joins them there are x - 2 cards per child. So, 20x = 21(x - 2). Can you solve that for x and use your answer to find the solution to the problem?
Answer is 840. Thank you.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
