PeterDonis
Mentor
- 50,243
- 26,334
PhDeezNutz said:I would think that parallel means "same sign".
Same sign of what?
PhDeezNutz said:A point that is stationary
I didn't describe a point, I described a curve. If you want to view it as a curve describing the "motion" of something, that something is certainly not staying at the same "point" (it goes from ##x = - \infty## to ##x = \infty##), so "stationary" does not seem like a good word to describe it.
PhDeezNutz said:the x-axis is literally the position correct?
It's a coordinate line describing the range of possible positions in the ##x## direction.
PhDeezNutz said:time stays the same while position changes.
More precisely, coordinate time stays the same while position changes.
PhDeezNutz said:I don't know how to interpret that.
Well, we're talking about hypothetical objects that can "move" on spacelike trajectories. This particular spacelike trajectory covers every possible position on the ##x## axis in zero coordinate time. What does that suggest? (For example, what coordinate "speed" would you say such an object has?)
PhDeezNutz said:I don't see any other way how ##\frac{dt}{ds}## can change with frames without considering relative motion.
First, what is ##dt / ds## for the curve I described, where the only coordinate that changes as a function of ##s## is ##x##?
Second, what does that same curve look like if we Lorentz transform to a different frame? I.e., what will the four functions ##t'(s)##, ##x'(s)##, ##y'(s)##, and ##z'(s)## look like? Assume we are doing a Lorentz boost in the ##x## direction (which means ##y' = y## and ##z' = z##, so only the ##t'(s)## and ##x'(s)## functions are of interest).
Third, given the answers above, will ##dt / ds## stay the same when we transform to the new frame, or will it change?
