Choosing a capacitor based on desired output pulse
To determine the necessary capacitance for a super capacitor that will discharge a large pulse, the formulas Q = CV (charge stored equals capacitance times voltage) and I t = Q (current times time) are essential. It's important to consider the voltage drop during discharge, as only the charge difference between starting and finishing voltages will be usable. Additionally, understanding the internal resistance of super capacitors and their discharge limits is crucial, especially for short pulses. The discussion emphasizes the potential dangers of high current and recommends consulting a licensed engineer for safety. Proper calculations and expert guidance are vital for successful implementation.
Undacuva
Hi folks,
I need to get a super capacitor which will be charged by a car battery and then connected to let out a massive pulse. (Yes a bigger pulse than my 450CCA battery can give). But first I need to work out how much capacitance will be needed. I'm not sure of the formula.
Thanks
Well I suppose you need Q = CV the charge stored is the capacitance x voltage
and I t = Q the current x time for your pulse is the amount of charge needed.
(Edit: or for varying current Q = integral I dt )
Though you will need to think about the fall of voltage during discharge, as only the difference in charge between the starting and finishing voltage, will be available.
Maybe some figures for your requirements (and description of task?) would be useful for people trying to help?
I have no special knowledge nor experience of super capacitors, so I don't know what their internal resistance is, nor whether there are any other limits on their discharge rate. (I assume you are looking at a very short pulse here?)
Edit: Link here to Sizing an Ultracapacitor for your needs
Likes Undacuva
The amount of current you are asking about is potentially lethal. Your design should be discussed in detail with a licensed engineer.
Thread closed.
