Christofle symbol and determinant of metric tensor
off-diagonal
Hi, every one I'm newbie here. I have a few problem with my study about GR.
Here's a problem
\partial_a(g^{ad})g_{cd}-\partial_d(g^{ad})g_{ac}=\\0
Could I prove these relation by change index (in 1st term ) from a -> d and also d -> a?
and let's defined {g}=det{\\g_{ab}\\}
{g^{ab}}\partial_c(\\g_{ab})=\frac{1}{g} \partial_c(\\g)
How I prove these equation ? Any one got an idea?
Yes. (You also have to use that the metric is a symmetric tensor: g_{ab}=g_{ba}).
I haven't given much thought to this specific identity, but the only time I proved an identity involving the determinant of the metric, I had to use this crap.
By definition \sqrt{-g} is a tensor density of weight one. As a consequence of this and the fact that the covariant derivative of the metric is zero, one has the result
\nabla_a\sqrt{-g} = \partial_a\sqrt{-g} - \Gamma^b_{\phantom{b}ab}\sqrt{-g} = 0
It's trivial to go from here to the result you want to prove.
You can check Ray d'Inverno's book on GR; in chapter 7 I believe he derives these things quite extensively :)
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
