What is the equation of the tangent line to a circle passing through the origin?
The discussion focuses on finding the equation of the tangent line to a circle defined by the equation x^2+y^2-6x-2y+8=0 that passes through the origin (0,0). The center of the circle is identified as (3,1) with a radius of √2. The tangent line can be expressed in the form y = kx, where k is the slope that needs to be determined. To find k, the intersection of the tangent line with the circle's equation is analyzed, leading to a quadratic equation where the condition for tangency is that the discriminant equals zero. The discussion emphasizes the geometric relationship between the circle, the origin, and the tangent points.
lPhoenixl
Equation: x^2+y^2-6x-2y+8=0 Find the center and the radius.
(Help) : Find the equation of the tangent to the circle above that passes through the beginning of axis O (0,0)
I found the center and radius and i believe the values are : C (3,1) and R =root(2) but can you explain me the second one
Sorry for my english.
I hope you'll understand it.
Thank you.
Your center and radius check out:
(x-3)^2 + (y-1)^2 -2 = x^2-6x+9+y^2-2y+1 -2 = x^2 + y^2 - 6x - 2y +10 - 2
Since your tangent line crosses through (0,0), it will be of the form x=my, where m is the slope. It will be perpendicular to your circle, so the formula for a line crossing through the tangent point and the center of the circle will be (x-3) = (-1/m)(y-1).
Now you need to find a slope "m" that will create an intersection between those equations that is on the circle: (x^2 + y^2 - 6x - 2y +8 = 0).
Also:
If you draw a picture, you will notice that there are two solutions. In both cases, a right triangle can be formed between (0,0), (3,1), and the tangent point. In both cases, the length of the hypotenuse will be sqrt(3^2+1^2) and the length of the leg that extends from the center of the circle will be sqrt(2). So the distance of the tangent points to the origin (0,0) can be easily computed.
So both tangent points will be on a circle centered at (0,0) with that radius. I'll let you set up that equation.
How did you find the center and radius?
I'm assuming that you only want an answer from the OP on this.
Yeah, I misread what the OP was asking. Thought s/he had obtained the center and radius but was asking why the radius was sqrt(2).
The equation for the tangent line is going to be y = kx, where k needs to be determined. You are looking for the intersection of y = kx with your circle. If you substitute y = kx into the equation for your circle, you get a quadratic equation, with the roots being the two points of intersection. If the line is tangent, there will only be one point of intersection (double root). This will be when the discrimanent is equal to zero.
17K
  • · Replies 17 ·
